I'm doing a cargo area. Bolted into a chrome moly frame.
Bunnings, a caravan builder or speciality aircraft wood.
I'm after the lightest strongest available with cost In mind.
It's not structural.
Thanks Lyndon
Very much depends on the configuration of the aircrafts (fuselage).
My Sonex is volume challenged (limited cargo space).
It has a fabric luggage/cargo area (up to 18kg) behind the seat with a zip lid that doubles as a shelf, accessible in the air - good for maps etc.
Accessible via two seat back hinged aluminium panels, an under/behind seat back, "pocket" (7 kg) This full fuselage width, triangular in cross section, stowage area has been created using very thin/light aviation grade plywood, as the back. Its for infrequently used items that I like to have with me on every flight eg first aid kit, tools, windscreen cleaning kit, jack, spare inner tube, etc
Not yet modified , is the under seat space - If I do this it will be using the same system as for the seat back.😈
 Balsa Wood ' is ' a hard wood ,with densities from ' super-light ' to very heavyweight .
spacesailor
