Underwood Posted June 25, 2025 Posted June 25, 2025 Having moved my Oil cooler to a position that allows its own air intake instead of piggybacked behind the Coolant radiator, I now have the opposite problem of over cooling the oil. cant get max above 80c so will have to blank some of the oil cooler probably use neoprene wrap...not a problem But allong with the low max temps its also taking ages to reach temp before flying so I'm gonna fit a thermostat. (thermostasis unit) Was just wondering do any of you guys fit them?, or are your ambient temps high enough that warm up is hardly ever a concern? 1
FlyBoy1960 Posted June 25, 2025 Posted June 25, 2025 They work great, i think i still have a new one laying around somewhere. Let me look. 1
facthunter Posted June 26, 2025 Posted June 26, 2025 Watch how you PLUMB it. It must not impede the Oil flow. It's also something else to go wrong. Nev 1
PapaFox Posted June 26, 2025 Posted June 26, 2025 We just cover half of the oil cooler in winter and accept the upto 10 mins from start to wheels up as a good time for the rest of the motor to warm up evenly and by ready for the cold air charge that comes with flying speed 1 1 1
IBob Posted June 26, 2025 Posted June 26, 2025 I bought an auto one (not Thermostasis), have seen them on Rotaxes, but decided not to instal it as they can fail closed: that is fail in the radiator bypass position. If installing one I would want to check the fail position. 1
skippydiesel Posted June 26, 2025 Posted June 26, 2025 7 hours ago, Underwood said: Having moved my Oil cooler to a position that allows its own air intake instead of piggybacked behind the Coolant radiator, I now have the opposite problem of over cooling the oil. cant get max above 80c so will have to blank some of the oil cooler probably use neoprene wrap...not a problem But allong with the low max temps its also taking ages to reach temp before flying so I'm gonna fit a thermostat. (thermostasis unit) Was just wondering do any of you guys fit them?, or are your ambient temps high enough that warm up is hardly ever a concern? I have one, never used - came with the aircraft. I can only sympathise with those that must endure long cold winters - living near Sydney, Australia, I enjoy a more moderate environment. I still "blank" off part of my coolant radiator & oil cooler when day temperatures routinely go below 25C. After much trial/error I arrived at a good compromise blanking, which I have photographed for future reference. In Cruise I have Oil temp. 90-95C. Coolant/CHT 90C. Climb OUT 100-105C. I find that the engine warm up period (Oil -50C) is well spent on checks, review of plan, etc I use adhesive backed refrigeration aluminium tape. Easy to cut & apply - can leave a residue when removed. Residue responds to most hydrocarbons. Reasons for use - Engine operated in seasonally very cold climates eg. N. America, UK, N Europe etc Speeds warm up. Reduced fuel consumption & frustration. Certainly important in cold climate opps but more of a perception benefit, in warmer climates May maintain even engine temperatures on descent - assist with carburettor ice prevention (if fitted) Reasons against - Significant added complexity = more to go wrong = heightened risk. From memory, at lest 4 additional joins in oil supply hose. All things mechanical will fail. Increased weight. Probably a minor concern however every minor increase adds up. Cost. Depending on arm length & depth of pockets, may or may not be an issue.😈
