Looking for a short length of SCEET ducting , ID 2" , often referred to by Dash Number -8.
300mm/1 ft would be ideal. Will consider longer/shorter.
Living in hope 😈
46 minutes ago, skippydiesel said:
What!!! Not a one with a bit of leftover SCEET ??
What about SCAT?😈
Your local friendly lame will have some.
42 minutes ago, turboplanner said:
We've been on these treasure hunts before. The information keeps changing.
Hi Skip, i have some about a mtre long its black with a wire outsde 50mm its yoursif you can use it
Cheers Gareth
You can get it from automotive suppliers. Sceet is lined with the wire coil sandwiched between the layers, Scat is not. The perceived issue with Sceet is that the inner lining can become detached though it has a higher temperature range and is more flexible than Scat. Usually double stitched either side of the wire coil and allows for smoother airflow. A metre of No 9 or 10 cost me about $45.00. Over $200 from Spruce.
Cheers Gareth
Hi Gareth - which type do you have, SCEET or SCAT ?
It came with a job lot i got from a guy selling aitcrafy stuff probanly sceet i will take pic in the morning and send it to you
Thanks mate!😈
If there is an inner liner and no wire coil showing it is sceet. Sceet is also double stitched. If it has no inner lining and the wire coil is visible it is scat.
Sceet        Scat
image.jpeg.160ff6013cbe818c2e16d6e9bf9687eb.jpegimage.jpeg.fdf005ca8e659da924ef6f067af8f353.jpeg
Edited by kgwilson
Thanks. . I didn't know that nice smooth inside was even available.
My turbo Delica has " scat ' .
But , would have thought " sceet " would be better for the ' turbo/ inter-cooler/ induction ' tube .
spacesailor
The ' original ' Delica scat holds a lot of turbo oil . When it has it's annual clean-cut  .
I have to stand it on end .to drain the oil out , as it just pools when horizontal.
spacesailor
I assumed it was only ambient air.  If you're leaking oil, the engine may runaway. Not turn off. Nev
Your turbo is not likely to be creating pools of oil in the intake hose, I'd suggest it's coming from your engine blowby, and also a possible faulty PCV valve.
A faulty PCV valve (clogged or stuck shut) will vent excessive blowby into the intake, and in well-worn engines, that blowby is carrying oil as well. A faulty PCV valve will also prevent proper oil return to the sump (or crankcase) from the turbo.
Your enclosed engine oil system should contain negative (vacuum) or zero pressure, thanks to a properly-working PCV system. Small 4 cylinder engines don't develop a lot of negative sump pressure, but it should be zero pressure at least.
Bigger engines (V8's, V6's and L6's) have strong negative sump pressure, you can measure this quickly by removing the dipstick and holding a small piece of paper flat against the dipstick tube.
If there's good vacuum in the sump, the paper will be sucked flat against the dipstick tube.
If blowby pressure is immediately very obvious, or if the paper is blown away from the dipstick tube, your engine is very well worn, or your PCV valve is faulty or plugged, and needs replacing. New PCV valves are not expensive.
Below is a good Danish website, with a more extensive explanation of the PCV/turbo problem.
https://support.nissens.com/en/material/engine-crankcase-ventilation
FYI;
Most suppliers of SCEET & SCAT are now selling in lengths of 3 ft to 11 meters BUT tend to quote in the cost per foot (to suck you in?).
This can be quite expensive stuff to buy especially when only a small length is required and you are forced to purchase the minimum?
SkyShop would seem to be in a minority of one - they quote & sell per foot SCEET - 8  (2in) @ $25.20/ft 😈
  • 3 weeks later...
HELP NEEDED
I have my SCEET, Dash 8, 2' ducting.
I would now like to cut it to length, prepare & install it.
Naturally I have Googled how to do this. So far have only found SCAT video/information on how to.
SCEET has an inner membrane/lining (SCAT does not) making the SCAT videos of academic interest only.
Anyone able to help????😈
Edited by skippydiesel
1 hour ago, skippydiesel said:
HELP NEEDED
Maybe go back to the manufacturer's storage and despatch people if you can get to them. Often those guys who have to do it all day long, and neatly, make their own tools or have a brilliant cutting method.
I just cut it with a Stanley knife at 90 deg & where the cut intersects the wire coil I cut that with side cutters. The spring tension will cause the cut end to distort a bit from round but that doesn't matter as your hose clamp will be back further to create a good seal.
You have to cut the wire in both instances. Do it FIRST and then mark where to cut  the rest.  Allow a bit extra to fiddle if you are not confident of getting it square . The "lined" one won't concertina like the other or be able to bend as well.  Nev
Gave it go yesterday - SCEET does no behave the way SCAT does (in the videos) - the wire does not come away without causing damage to the inner membrane/lining
