Hi Everyone,
     We are thinking of moving to Taggerty / Alexandra shortly. Does anyone know of a private airstrip in the area that might accommodate a low wing LSA long term?
Taggerty airstrip is no longer in use and Lilydale / Coldstream is a bit to far.
Thanks for any info.
Raaus is australia - VIC in the post title is victoria. Learn to read the post?
This Forum is international - learn to read posts😈
  • Caution 1
The OP asks for information regarding private airstrips around Taggerty, Victoria. Also mentions Coldsteam and Lilydale.
How much more information do you need in a post? Seems clear enough to me where he meant even without checking an atlas.
Thank you rgmwa - I did not mean this to become a slinging match - but it needed a response.
Skippy, the title and the question is abundantly clear enough - even to us Left Coasters. I think you should apologise to Murrayg for your narky questioning, it wasn't called for.
Hi Red,  Thanks for this - I have looked at that - but google satellite shows no sign of an airfield there (It is also known as Thornton airstrip) and I cannot find any contact details. It is certainly close enough though. I will do more digging on it.
Yea, it looks to be just over 300 metres can't find any contacts though maybe worth a drive to have a look
14 hours ago, murrayg said:
Jesus wept
I believe you are correct, if not factually, certainly 😈
Oooooh! certainly woke up this sleepy (parochial) Forum😈😁
  • Sad 1
Yes true - further up around Alexandra is a bit better. I do realise that I am grasping at straws a bit.
Not a lot of flat country around Taggerty.
I think your main options would be Lilydale ($110/month on tiedown, ~$550/month hangar but may not be available), Coldstream (soon to be redeveloped?), or maybe Mansfield (Walsh's).
Mansfield is an option but is over an hours drive, I will investigate Coldstream as well. Thanks
Get the Country Airstrip Guide for Victoria, or you can buy online subscription within AvPlan, there are several strips with the Owner/Operator contact phone numbers:
YTGG - Taggerty
Y0RS - Murrindindi (Narangi)
YYEA - Yeaburn
YMEO - Merton
below are in ERSA:
YMFD - Mansfield
YCEM - Coldstream
YLIL - Lilydale
there are others too, but decided not to publish their details..
Hi Bosi,
              Thanks for these - I have looked at most of these - Murrindini looks good but unfortunately is around the other side of a mountain range. Merton is probably the best realisticly.
On 19/09/2024 at 2:13 PM, skippydiesel said:
No State/No Country  -Typical Mexican living in the Centre of the Known Universe😈
you must live under a rock if you haven't heard of lilydale or coldstream.  have you gone off your meds again.
On 20/09/2024 at 6:15 PM, murrayg said:
Hi Bosi,
why are you leaving albany. did that 14 years ago and still wish we had of stayed there.
Hi Bosi,    Temporary move for 5 or so years - just to explore the east coast easily. We will keep our Albany place to move back to in our dotage.
