skippydiesel Posted September 2, 2024 Posted September 2, 2024 On 31/08/2024 at 8:51 AM, Moneybox said: Some people might not be happy to buy from overseas. If that's the case I'd happily buy a few and post locally however I'm not into buying and selling anything anymore just happy to help. I just checked the price of 1 pk Wacker P12 Thermal Paste , delivered Australia, NSW - Eu 101.60 becomes $166.05 Au Did you read my post for a recommended alternative, available in Australia from Mektronic $65.15 (delivered AU) https://mektronics.com.au/products/mg-chemicals-heat-transfer-compound-silicone-150
Red Posted September 2, 2024 Posted September 2, 2024 16 minutes ago, Moneybox said: Am I missing something? Perhaps missing How small an amount 20ml is. 1
skippydiesel Posted September 2, 2024 Posted September 2, 2024 On 31/08/2024 at 8:51 AM, Moneybox said: Some people might not be happy to buy from overseas. If that's the case I'd happily buy a few and post locally however I'm not into buying and selling anything anymore just happy to help. Am I missing something? Dont know how the top bit transferred. Yes, you missing the currency conversion on the product itself and the exorbitent delivery cost also in EU - a trap for the 😈
skippydiesel Posted September 3, 2024 Posted September 3, 2024 Wacker from EU - Just now - EUR 132.80 = AU 218.51= $10.96/ml Compared with; In Au - MG Chemicals for $65.15 = about $ 0.44/gm True the Wacker P12 remains Rotax recommended product, however the MG has been recommended by a highly respected Rotax technician on the Rotax Owners Forum with the statement MG Chemicals Heat Transfer Compound Silicon as an appropriate substitute, that he has used to good effect for 23 years. I am merely presenting, what I believe is a rational/cost effective alternative. There are maintainers, out there, who are obsessed with following every detail of Rotax recommended service/items, to the point where their aircraft is grounded due to their inability to make a logical alternative decision eg to use an available product, at reasonable cost, that meets/exceeds Rotax standards, when the recommended product may be difficult to access and prohibitively expensive. Ultimately, I support the right of the owner/maintainer, to use whatever they wish to look after their Rotax. 1
Arron25 Posted September 4, 2024 Posted September 4, 2024 (edited) 15 hours ago, Moneybox said: Yes 20ml is small but we don’t replace spark plugs often and a very small amount is needed for each application. I bought a 20ml tube for my (computer repair) shop use 15 years ago..... probably used 1/10th maybe... Never use what the manufacturers supply, preferring to use my own.. Edited September 4, 2024 by Arron25 2 1
skippydiesel Posted September 4, 2024 Posted September 4, 2024 2 hours ago, Arron25 said: I bought a 20ml tube for my (computer repair) shop use 15 years ago..... probably used 1/10th maybe... Never use what the manufacturers supply, preferring to use my own.. That's great Arroin - If you can make it to/better than Rotax specifications. As I pointed out, some posts back, there are lots of heat sink paste options in the marketplace. As a non technical person, I am "wedded" to Rotax specifications. This does not mean I always purchase from RoTAX but do use "stuff" that meets/exceeds the Rotax standards. 1
skippydiesel Posted September 4, 2024 Posted September 4, 2024 4 hours ago, Moneybox said: I'm not disagreeing with what you say, just your calculation 218.51/60 = $3.64/ml 🤪 Must have punched some doggy buttons - yes $3.64/gm 1
onetrack Posted September 4, 2024 Posted September 4, 2024 There's a big difference between grams and millilitres, you're comparing apples to oranges. Grams is weight measure, ml is volume measure. You can have a vast difference in quantity for the same numerical amount, depending on the S.G. of the particular product. 1
danny_galaga Posted September 4, 2024 Author Posted September 4, 2024 1 hour ago, onetrack said: There's a big difference between grams and millilitres, you're comparing apples to oranges. Grams is weight measure, ml is volume measure. You can have a vast difference in quantity for the same numerical amount, depending on the S.G. of the particular product. Eg, a millilitre of mercury compared to a millilitre of air. And put another way, what volume does a gram of mercury occupy, compared to a gram of air. 1
spacesailor Posted September 4, 2024 Posted September 4, 2024 A gram of mercury occupies how many millilitres. " 0.074 millilitres " spacesailor
Red Posted September 4, 2024 Posted September 4, 2024 Yea but dont forget 1 millilitre of water has a mass of 1 gram, Ill bet the wacker paste isnt far off from that equivalence
Freizeitpilot Posted September 4, 2024 Posted September 4, 2024 4 hours ago, Red said: Yea but dont forget 1 millilitre of water has a mass of 1 gram, Ill bet the wacker paste isnt far off from that equivalence 2.1 g/cm3 WACKER CHEMICAL-54764_60003095-ENG-SDS_VD.pdf 1
skippydiesel Posted September 4, 2024 Posted September 4, 2024 https://mgchemicals.com/downloads/tds/tds-860.pdf 1
danny_galaga Posted September 5, 2024 Author Posted September 5, 2024 13 hours ago, spacesailor said: A gram of mercury occupies how many millilitres. " 0.074 millilitres " spacesailor Damn, that's nearly as dense as me 😄 1
onetrack Posted September 5, 2024 Posted September 5, 2024 So.... these often exorbitantly expensive heat transfer compounds are revealed in the TDS's, to contain nothing more than silicone oil, and zinc oxide as an inorganic, largely inert filler. Both are relatively cheap - silicone oil is noted for its heat transfer properties, and zinc oxide is used widely in a large range of products, with sunscreen being a major user. Silicone oil has been used in viscous fan clutch hubs for donkeys years, it's not exactly worth stealing, like catalytic converters are. So why the massive charges for this heat transfer compound as soon as it's labelled for aviation use? It sounds like the classic sideshow spielers have got into the heat transfer compound market. Skippys on the mark - no point in being ripped off simply because Rotax recommend a certain brand of the product.
skippydiesel Posted September 5, 2024 Posted September 5, 2024 4 hours ago, onetrack said: Skippys on the mark - no point in being ripped off simply because Rotax recommend a certain brand of the product. Thank you for your kind words sir. As to the recipe containing fairly common cheap products - I guess there is a degree of refining, meeting of standards, consistency and of course packaging & marketing the "sunscreen" which all adds up. Then there will be the 100% ++ markup, to keep the kids in private school, the facilitate the annual overseas holiday and the new luxury car every 3 years or so.😈 1 1
Red Posted September 5, 2024 Posted September 5, 2024 I expect if you nip down to your local Computer store (if you have one) you'd get a small tube for a reasonable price 1 1
Red Posted September 5, 2024 Posted September 5, 2024 9 hours ago, Freizeitpilot said: 2.1 g/cm3 WACKER CHEMICAL-54764_60003095-ENG-SDS_VD.pdf 171.86 kB · 5 downloads Oo thanks, much heavier than I thought 1
skippydiesel Posted September 5, 2024 Posted September 5, 2024 14 hours ago, Red said: I expect if you nip down to your local Computer store (if you have one) you'd get a small tube for a reasonable price Problem is - does it meet/exceed Rotax specifications? Important to me, may be not to you. "Not the sharpest tool in the shed" so am dependent on Rotax specifications, resulting in, the right product for the given job, even if I don't buy from Rotax.
Arron25 Posted September 6, 2024 Posted September 6, 2024 On 06/09/2024 at 8:12 AM, skippydiesel said: Problem is - does it meet/exceed Rotax specifications? Important to me, may be not to you. "Not the sharpest tool in the shed" so am dependent on Rotax specifications, resulting in, the right product for the given job, even if I don't buy from Rotax. A few years ago Ford tried to void warranty if you did not use Genuine Ford filters until it was shown the 'genuine' were just repackage Commercially available filters.. Not made specially for Ford as claimed. Manufacturer 'specifications' have MORE to do with Marketing and Brand Share than actual Hard and Fast specification requirements. In this case..(and most others) as long as you are buy from a reputable supplier (ie not Online internet/facebook) the product will match or exceed anything with a pretty label stuck on it by a manufacturer. 2 1
skippydiesel Posted September 7, 2024 Posted September 7, 2024 1 hour ago, Arron25 said: A few years ago Ford tried to void warranty if you did not use Genuine Ford filters until it was shown the 'genuine' were just repackage Commercially available filters.. Not made specially for Ford as claimed. For me a specification is not a brand or marketing tool. Manufacturer 'specifications' have MORE to do with Marketing and Brand Share than actual Hard and Fast specification requirements. Specifications are standards, that the engine manufacturer has determined, will "do the job"eg an oil hose peak/continues pressure, temperature, bend radius, etc or in the case of heatsink past (just winging it) ingredients, ratios, temperature, conductivity, etc . In this case..(and most others) as long as you are buy from a reputable supplier (ie not Online internet/facebook) the product will match or exceed anything with a pretty label stuck on it by a manufacturer. How can you know that you are purchasing a product that is equal to or better than the one specified by Rotax, without comparing specifications? Rotax offer some specifications , other times recommended manufacturer/product. For the latter it is usually possible to obtain the specifications from the manufacturer, for the recommended product eg Continental supply oil hose for Rotax 912 engines - you can only purchase the specific oil hose from Rotax BUT Continental kindly publises the performance specifications for the given hose, which can then be used to find an equal or better performing hose from an alternative reputable supplier eg Gates. 1
Blueadventures Posted September 7, 2024 Posted September 7, 2024 1 hour ago, Moneybox said: I want to buy a new electric fuel pump for the Sportstar but I’ve been too busy to research it. I put Sandra onto Virgin for the flight back to Perth last night now I can get the credit card out again. 1st option is like for like. Is it a Facet pump? If so buy from a good seller; could be poor knock copies out there. What is in it now?
skippydiesel Posted September 7, 2024 Posted September 7, 2024 Moneybox - Rotax have specifications for Boost Pump maximum fuel pressure. Your aircraft manufacturer may have a recommended pump to do the job. I would stick with the recommendation unless you have good cause to do something else. Your existing pump is likly to have Maker, Model. Part Number somewhere on it (If it a Facet it is normally embossed , not always, on the mounting bracket Should you be unable to determine the existing pump you should start by reading the following" Always with reference to your engine ( 912 ULS 100 hp?) Installation Manual, Chapter 73-00-00 , Engine Fuel & Control, Pages 7-8, Boost pump Max pressure 4.5 psi Operators Manual, Chapter 5, Performance & Fuel Consumption, Pages 8, 5.2) Fuel Consumption, Specific consumption at max. continuous performance, 27L/hr It not quit as simple as just purchasing a pump that will deliver 4.5 psi. Your aircraft likely has a return fuel line with restrictor jet somewhere in the line. ie the pump must accommodate this flow. The maximum fuel your engine will burn is 27L/hr, the pump must accommodate this flow. The Boost pump should deliver at least 2 psi - 4.5 psi in work, accommodating both carburettor & return line flow, if it is to act as an emergency fuel supply system, say in early Climb Out (Max power). Most aircraft in the recreational class will use a Facet Cube pump https://facet-purolator.com/specifications/ 1
onetrack Posted September 7, 2024 Posted September 7, 2024 You'll be right. I went through the border in mid-May with 4.5 tonnes of earthmover parts covered in Victorian dirt and crap, and the young bloke on duty was pretty cheery, and simply blew the load down with a leaf blower, and let me through! And the truck was unregistered, too! LOL However, he did need my movement permit number for his records. Weed seeds are what they're mostly concerned about, and if you've come from any area where known problems exist.
