kgwilson Posted January 29, 2021 Posted January 29, 2021 The concept is the same as the FAA allowing Boeing to certify itself which didn't end well. The 2 scenarios are vastly different in complexity and legallity. I wonder though how much oversight and evidence is required by RAA or does it just accept what a manufacturer says.
RFguy Posted January 29, 2021 Posted January 29, 2021 How does these requieements, limits compare to the world of VH-experimental (non builder) if you have a LAME/engineering org that will sign it off ?
old man emu Posted January 29, 2021 Posted January 29, 2021 The aircraft doesn't have to only be a VH experimental. As long as you get an Engineering Order from an authorised aviation engineer, you can do whatever you want to do. A change might require a new W&B determination if the change in weight is substantial (over 5kg, I think).
RossK Posted January 30, 2021 Posted January 30, 2021 LSA rules are clear, if factory no longer supports the aircraft, bankruptcy etc, then it must go to E reg.
Yenn Posted January 30, 2021 Posted January 30, 2021 The weight change for a new weight and balance is not 5kg, it is a percentage of max weight. 5kg on my plane would have a much greater effect than 5kg on a C172. 1
old man emu Posted January 30, 2021 Posted January 30, 2021 Civil Aviation Order 100.7 Instrument 2015 6.3 Unless otherwise agreed to by CASA, the load data sheet for an aircraft must be renewed before further flight whenever, as the result of a modification or as otherwise shown in the record of weight alterations, changes exceeding the following have occurred: (a) for aeroplanes: (i) the empty weight has changed by more than 0.5% of the MTOW or 10 kg, whichever is the greater; or (ii) the empty weight CG has changed by more than 2% of the maximum permissible centre of gravity range or 5 mm, whichever is the greater; BUT: 1 Application This Order does not apply to the following: (a) a balloon; (b) an airship; (c) an aircraft that: (i) is registered by a sport aviation body; and (ii) has been weighed in accordance with the sport aviation body’s procedures, as the procedures have been accepted or approved by CASA at the time the aircraft is weighed. Is RAAus sport aviation body?
