Below 25 degrees is Winter? Well maybe in the tropics. At 30 deg South Winter is when the ambient temperature is below 15 deg & further South that is positively balmy.
They are just figures for engine cooling management that I adopted at the time - seemed to work for that aircraft.
Personally, I find any temperature below 21C to be cold and above 35C to starting to get a tad warm. 40C is hot , 45C a bit of a scorcher. If you add significant humidity to 30C and above the perceived temperature seems to be about 5C more and getting a bit sweaty😎
Ambient has much more effect on oil temperatures than the head temps as the difference as a % varies more and heat flow is proportional to temp. difference. A slow airspeed make it all MORE critical.   Nev
