RFguy Posted October 25, 2020 Posted October 25, 2020 kg said : "Mine are Stereo plugs and most know of are stereo these days." --yeah there are a mix of stereo and mono plugs, and often the socket is a mono socket, so you end up driving both sides of the headset in parallel (not really the right way, may not be strictly wrong but certainly not right). I am sure it depends on the aircraft and the degree of naivety on the part of the installer or designer.
RFguy Posted October 25, 2020 Posted October 25, 2020 Hi SplitS. will have to test all those (in your photo) objectively someday ! I am on a project in the USA doing noise cancelling intercoms and headsets for MRI machines... The noise is loud...
petercoota Posted October 26, 2020 Author Posted October 26, 2020 RFguy, your project in the US explains your knowledge level on this subject. I'm hoping to have a reply from nflight tomorrow, I'll post their response.
RFguy Posted October 26, 2020 Posted October 26, 2020 I've been messing with helicopter intercoms and interfaces for ICS for about 25 years. Both Mil and Civil. I have only worked a little with GA intercoms, (A different plug for one....) but they seem to have the same stuff in them. GA intercoms seems to be cut down in flexibility compared to their 6 radio counterparts. I guess more like an IFR equipped GA aircraft. I am working on the MRI headset project because of my additional knowledge of RF. The MRI is a high precision radio transceiver... Given the variables , many sub-optimal combinations of impedances will still work just fine. Maybe not perfect, but workable. - The recent stuff installed in LSAs is likely to be the most tolerant of variables, compared to a 40 year old box of old and poor transistors. -glen
petercoota Posted November 1, 2020 Author Posted November 1, 2020 I've had a series of replies from Nflight about their attachable Mic setup. They seem to favour the Bose 35 11 over the Bose 700 as the older model (the 35) is less bulky & has very similar ANR in a flying environment. The Sony 1000 xm4 requires an adaptor, which they sell, but it adds to the overall bulk of the headset. They confirmed a comment that RFguy mentioned about adaptors that may not be wired correctly. Another factor that hadn't been raised in this chat was the impact that auto squelch might have on different brands of headsets connected to the same system. I have a G3X system & nflightmic advice was that I should at least stick to the same brand as my existing headset (Bose A20). When I checked prices, the Bose 35 11 is a lot cheaper than the newer Bose 700 & the Sony xm4. So, for me the choice seems clear, I'm going to go with the NFlightMic PRO & a Bose 35 11. They also mentioned that Downunder Pilot Shop is an agent for their gear 1
RFguy Posted November 1, 2020 Posted November 1, 2020 does your intercom system have separate mic squelch settings for each headset input ?
petercoota Posted November 1, 2020 Author Posted November 1, 2020 I have to admit to not knowing. It's a dual G3X with a GTR 200 radio, no separate intercom panel. I'll look next time I'm at the aircraft......Peter
Blueadventures Posted November 1, 2020 Posted November 1, 2020 28 minutes ago, petercoota said: I have to admit to not knowing. It's a dual G3X with a GTR 200 radio, no separate intercom panel. I'll look next time I'm at the aircraft......Peter Details will be in the user manual and set up instructions, panel adjustments and procedure to adjust the internal factory setting. For example I have a copy of the adjustment page and note my setting internal for my headsets; then if someone brings there own set and I make internal setting adjustments i can go back to my original settings after. Being 'Trig I list them as a percentage.
petercoota Posted November 1, 2020 Author Posted November 1, 2020 That's a good idea, I'll have a look at the CONFIG setup & take a photo. I've taken photos of what I thought were important, like the TX, never thought of the radio....Peter
RFguy Posted November 1, 2020 Posted November 1, 2020 no no no I meant the mic squelch IE the VOX threshold, the threshold over which the microphone activates, and you can hear noise and voice through the intercom. In the Brumby, it has a single VOX / mic squelch for BOTH handsets. If the headsets have different sensitivity microphones, then the setting of the mic squelch will be unlikely to be correct for both mics (since they have different level outputs) glen
petercoota Posted November 1, 2020 Author Posted November 1, 2020 Misunderstood you. Mine has only a single control.
RFguy Posted November 1, 2020 Posted November 1, 2020 yeah, and that's ONE limitation of mixing headsets I'd reckon. Not that it isnt surmountable, easy enough to reduce the level from the louder headset in the inline adaptor with one resistor....
petercoota Posted November 12, 2020 Author Posted November 12, 2020 Bose QC35ii & nflightmic microphone assy arrived today. Assembled easily, certainly smaller & lighter than the Bose A20. I’ll take some side by side pics & take them flying in the next few days & post my thoughts. 3
Blueadventures Posted December 15, 2020 Posted December 15, 2020 On 12/11/2020 at 5:42 PM, petercoota said: Bose QC35ii & nflightmic microphone assy arrived today. Assembled easily, certainly smaller & lighter than the Bose A20. I’ll take some side by side pics & take them flying in the next few days & post my thoughts. Hi Peter Any update and pics about how you found the build and use of your headset kit, I’m looking at a set up soon with either the Bose or Sony base headset. Thanks in advance for any feedback comments.
petercoota Posted December 15, 2020 Author Posted December 15, 2020 Sorry I haven't followed up, my aircraft has gone U/S so I haven't been able to do a side by side flight test. The pics don't tell you much, 1997 is the nflight, 1999 Bose a20, 1995 both sets, 2002 nflight, 2003 Bose. The nflight kit was very complete & well packaged, not a backyard job. The nflight is less bulky, but not a lot in it. I leave my headsets hanging in the aircraft, so bulk is not an issue. The nflight when attached to the headphones is a tight fit in the bag, rather fiddly. It looks like a few months before I'm flying again, so you'll have to rely on comments by others. For me, I rarely have a passenger, a new Bose A20 is nearly $1800, this nflight setup, complete, including local bought headphone freight etc was under $800. Sorry about the crappy pics, my iphone lens must have had a fingerprint on it. Let me know how you go...Peter 1 1
skippydiesel Posted December 15, 2020 Posted December 15, 2020 You dont look too happy - probably the aircraft problems😀
