SSCBD Posted August 13, 2020 Posted August 13, 2020 Yes you might be having a bad day, but it's probably not a "tell your boss you set off the fire suppression system at the Minnesota National Guard hangar and foamed all 10 aircraft” kind of bad day... 1
IBob Posted August 13, 2020 Posted August 13, 2020 How come there is no foam on the top of the choppers etc? Seems to suggest the foam came from somewhere outside the frame???
Yenn Posted August 13, 2020 Posted August 13, 2020 Reminds me of when I let off a foam extinguisher inside a cromwell tank. It looked just lovely foaming out of the turret.
M61A1 Posted August 13, 2020 Posted August 13, 2020 How come there is no foam on the top of the choppers etc? Seems to suggest the foam came from somewhere outside the frame??? The hangar fire suppression systems are often plumbed under the concrete floor and spray foam upwards. I have seen testing of such systems. Usually messy and time consuming as all aircraft and equipment has to be removed first. 1
walrus Posted August 13, 2020 Posted August 13, 2020 This is serious. I’m not sure what foam they used but some can be corrosive. This might take much more than a simple hose down to return the aircraft to service. 1
