The Savannah's come with a 50amp blade style fuse and holder...that is well more then needed for the DC side of the regulator
Normally I have never seen fuses in the AC side
Mark based on your post, I've been trying to locate the most suitable fuse for my battery (small, lightweight). My electrical mates think 150 A is overkill for my a J2.2. Are your Jabs 4s or 6s (and would that make any difference to the size of fuse needed?)
In trying to relocate this thread, I came across a related discussion a few years back with this interesting contribution from a well-respected source:
https://www.recreationalflying.com/threads/battery-isolator.23440/#post-264636
Actually I have 3 fuses in the engine bay.A 150A for the starter motor
Actually I have 3 fuses in the engine bay.A 150A for the starter motor, a 50A for the supply to the cabin and everything else, & a 15A on one of the AC wires going to the voltage regulator. I did have a 100A for the starter motor , but it blew, so I upped it to 150. The 150 and 50 amp fuses are mounted on the battery box with one large wire about 12cm long going to the positive terminal of the battery. I copied the set up from a friend’s Tecnam where we had to change one of the fuses which had corroded through (plane left outside in the rain by training school). The fuses in the AC charging wires is the one supplied with the Powermate regulator. It’s just a standard automotive inline blade fuse. BTW don’t use the fuses with a wire in a glass tube; the wire bends and work hardens with vibration, then breaks. Yeh, I know the Jab engines don’t vibrate, but I do have a friend who has an engine failure because of this.... the fuse was to his high pressure fuel pump on an EFI. Only use fuses where the fuseable element is supported.
I will always have a battery isolator within reach of the pilot in any aircraft..its your only true safety if there is a fire...first sing of smoke then kill the supply to and from the battery.
Mine in the girlfriend was mounted on the pax side on the front crossmember within easy reach while I was flying
I’m no expert, but: if the isolator is a an electrical controlled solenoid even once turned off, you still have power to the isolator/solenoid control switch. If its a mechanical switch, it means you either have the battery in the cabin or a bunch of large heavy copper wires in there with you that will still be live too, or a mechanical link to the isolator if it’s remote from you. And if your electrical fire is due to a short in the AC side of your charging system and/or the voltage regulator, isolating the battery will not affect this. Finally, assuming an electrical fire is due to a wire overheating and burning the insulation on the wire & then cutting through your wingspar, that would be due to excess current... which would be prevented by an appropriate sized fuse or circuit breaker. There is one scenario I could contemplate, and that is a lightning strike. Andeven then, I’m not sure an isolator would help. I experienced a lightning strike on a yacht...it vaporised the vhf antenna, the current flowed down the antenna coax to the vhf radio, which caught fire, releasing all the magic blue smoke that makes all things electronic work, and there to the ground bus and to the engine to earth in the saltwater through the gearbox and prop. All, and I mean ALL, electrical items connected to the negative bus, switched on or not, was toast. FWIW & that’s not much, I use an old aircraft battery isolator solenoid as a 200A relay on the yacht to power the electrical anchor winch. Finally, that smoke in the cabin might not be electrical, it just might be that your trusty plastic oil catch can decided to spray 50ml of old engine oil onto your exhaust (don’t ask)!
...If its a mechanical switch, it means you either have the battery in the cabin or a bunch of large heavy copper wires in there with you that will still be live too, or a mechanical link to the isolator if it’s remote from you. ..
Another possibility: a reliable remote control. I have a weighted, spring loaded lever next to my right knee, connected by a wooden rod to the battery's earth terminal. (The actual connection is the rounded tip cut off the brake lever of my first bike- a Speedwell - which slides forward to connect the earth cable with one engine mount nut.)
Despite the very light spring pressure holding it there, it has reliably carried starting current for a decade.
I have the battery behind the firewall, technically in the cabin, but being LiFePO4, I trust it more than a lead acid unit.
This is how it has been done on all certified aircraft since the dawn off time, a combined master/alternator switch allows all electrical power (battery and alternator output) to be shut off in fire or forced landing situations. Not sure how manufacturers are handling the self exciting permanent magnet alternator types found on jabiru/rotax machines.
Edited by Thruster88
  • Informative 3
A solenoid requires power to operate of course. The isolator I used in my aircraft is the removeable key type. A proper make/break switch. All the wire in my aircraft is tefzel...no auto style wire at all. The battery in the sav was right down the back the first port of call is the isolator then everything forward of that is controlled. It wouldnt matter what you had as a isolator if the battery burst into flames. You are most likely to have a severe fault forward of the isolator . I like the big clunky switches that give me a open circuit...I ahve seen too many solenoid/contactors locked shut in my time
You can wire it like the picture above no issue but like on any heavy machinery they still have that final part that isolates the battery completely..thats what I like
[ATTACH type=full" alt="images (5).jpeg]55972[/ATTACH]
I’m sure this set up is reasonably safe. But just to be clear: the logic of a system being ancient and on ‘certified’ aircraft means nothing. It’s the same as the fable of the farmer with the sick cow.
Agree
Old Koreelah, here is a photo.
Agree
I strongly disagree with your statement that being certified and tested over a long time means nothing. In the certified world faulty design or parts result in an airworthiness directive, owners bitch and moan about it but it makes aircraft safer. Am not aware of the sick cow fable.
The battery isolation switches rely on a spring for the disconnect just like a solenoid so I don't see any difference if they become welded. If the master solenoid was failing in certified aircraft there would be an airworthiness directive.
Farm/heavy equipment need after market battery isolation because while most circuits are cut by solenoid (often a long way from the battery) the alternator remains connected to the battery 24/7. Faulty alternator, dead battery BTDT. A master solenoid positioned AT THE BATTERY just like the certified aircraft will give that same complete isolation.
Sorry, been absent from this discussion for too long. Is that your 150A fuse?
That’s two fuse holders. The bottom one has a 150A fuse (starter motor), the top one I think has a 50A and goes to the master switch on the panel and a 25A circuit breaker.
Thruster 88 it seems the rest of my reply didn’t make it. But I wasn’t responding to ‘certified and TESTED’, but your previous statement which was ‘old and certified’. I maintain that just because it was done that way in the past, and even if it worked, it’s sometimes worthwhile to look at alternatives. The ‘old certified’ isolators I have come across probably worked reasonably well (‘worked’ as meaning providing reasonable safety), but they weighed a substantial amount. But I think the safety provided by a battery fuse provides similar safety for a big weight saving, and if I’m doing a power off out landing, not having to turn off the battery isolator is one less thing to distract me from getting my landing just so.
The sick cow fable. Farmer A who had a sick cow attended the local annual field day. Farmer A explained to another farmer, Farmer B, about the sick cow’s symptoms. Farmer B responded that he had had a sick cow with the same symptoms and that the generally accepted approach was to treat the cow in a certain way. The next year Farmer B saw Farmer A again at the annual field day and asked A how it went with the sick cow. Farmer A responded that he did what Farmer B suggested, but the cow died. Farmer B then remarked that his cow also died when treated that way too.
Mark, I am certainly not against new ideas, however the fuse idea is just plane silly. To do its job of cutting all electrical power so the risk of fire is reduced it must be capable of carrying the starter current. A fuse of this size will produce a mega spark and or burn all the small wires before blowing, you will be toast. The master solenoid used in certified aircraft also provides a method of stopping the starter if there is a malfunction with the start circuit. I don't post to be a smart a or to piss people off. I see the forum as a virtual pub full of interesting characters. ?
Well I might have an IGBT switch/CB. Since I am used to switching 6000 amps for brain stimulators...
  • 6 months later...
  • 5 years later...
I’ve lost one vehicle and fortunately not my life to a LiFo4 lithium battery. I know many still believe they are safe but I know differently.
Take a look at this video where this couple got lucky. They had the batteries isolated from their living area, they had multiple alarms, multiple fire blankets and multiple fire extinguishers. They were on the ground with the fire department on call. They were not several thousand feet above the earth when their battery burned.
Fortunately their battery just burned, mine didn’t, it exploded spreading metallic confetti throughout my camper and destroying everything with highly corrosive fumes. All metal components were badly corroded within days and the glass is coated with a solid layer of some sort of soot that feels like sandpaper.
I believe that if I’d been in the vehicle at the time I wouldn’t have survived.
Do you really want one of these batteries in your plane?
Hi Moneybox,
Sorry don't have the attention span to sit through 30+ minutes of folksy chat .
If known - What caused the malfunction??
What sort of Lithium battery was involved?
Do any of the above relate to the aircraft certified, Lithium-Ion /LIFePO4 such as those supplied by Earth X?
Mine were 120AH Solar King LiFePO4 as supplied for off grid camping or auxiliary automotive batteries. You can bury your head in the sand if you like but I don’t care if they claim to be aircraft certified. They still have the same chemical composition. My vehicle had been parked unused for a week prior to the battery explosion and fire that followed. In my opinion it’s a risk too great because a lithium fire is almost impossible to extinguish even when the emergency services are in attendance.
Nobody is going to be able to help you at 5000’ when the extreme heat produced by a lithium battery fire ignites everything flammable nearby.
I think more often than not the charging system and BMS (or lack there of) are the issue with Lithium batteries.
I have used lithium batteries for the last 15 and the only one that has ever blown up I shot with a 223
Are Lithium batteries actually an advantage in aircraft ?
Their lighter weight is often a negative for COG.
Why go with them ?
I use them because they are light in unmanned aircraft, my race car, my classic cars, my dirt bikes and ebike.
I have also used them as a backup battery for the airband in my old Supa Pup which had no built in electrics.
I'll be fitting one to my daily driver if the battery in it fails.
I have probably used over 1500 individual battery packs making up many different configurations from 4.2 volt up to 64 volt
I bought sodium ion last time. They were lighter than lithium for a higher CCA but low AH rating. For a start battery I need the CCA to spin a cold engine over rapidly but usually for just a few seconds. Sodium ion is perfect for that and the chemical composition says it’s not going to burst into flames ever.
