skeptic36 Posted November 11, 2015 Posted November 11, 2015 Hi all, I am doing some work to the fuel system on my trike atm and I'm surprised to find teflon tape on all the threads. These are installed at the factory. Should I use teflon or should I use Permatex Aviation Sealant, or something else? Thanks Regards Bill
rgmwa Posted November 11, 2015 Posted November 11, 2015 Loctite 567 also works. I've read that there's nothing inherently wrong with Teflon tape provided it's installed correctly. However it's not recommended because it's too easy to shred bits into the fuel system. rgmwa
Nobody Posted November 11, 2015 Posted November 11, 2015 Hi all,I am doing some work to the fuel system on my trike atm and I'm surprised to find teflon tape on all the threads. These are installed at the factory. Should I use teflon or should I use Permatex Aviation Sealant, or something else? Thanks Regards Bill The flared part of the fitting should not have teflon or sealant. The tapered thread part should have a fuel sealant not tape. Do not use RTV. A good discussion with pictures is here: http://www.vansairforce.com/community/showthread.php?t=130852&highlight=teflon AC43-13-1b says not to use teflon on the flared part of the fitting. (but is silent on the tapered part) http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentid/99861 1
facthunter Posted November 12, 2015 Posted November 12, 2015 Generally speaking teflon makes the part move too easily and it can get in the fuel. A tapered fitting (particularly an elbow) needs to NOT move in service. Nev
aj_richo Posted November 12, 2015 Posted November 12, 2015 NPT threaded fittings require sealing, ain't no other way around it. I haven't experienced any issues with Teflon paste
facthunter Posted November 12, 2015 Posted November 12, 2015 I'm referring to the use of tape, frequently incorrectly used. Nev
Guest ozzie Posted November 13, 2015 Posted November 13, 2015 Flared fitting, no. From what i have read. liquid thread lock (not sealant) may be used in high vibration areas. I have always tried to avoid using anything that will find it's way into a fuel system.
kgwilson Posted November 13, 2015 Posted November 13, 2015 Permatex is the best IMHO. It seals, is not affected by petroleum products but does not go hard like some others so removal is not an issue. High strength threadlock compounds can be a problem as they can be difficult to undo.
M61A1 Posted November 13, 2015 Posted November 13, 2015 Loctite 567 is good for tapered thread fittings. If you feel the need to use thread tape on a flared coupling, stop working on machinery and get a desk job. If a flared coupling leaks at normal torques, it's damaged and should be replaced. I have worked helis that specify a threadlocking liquid on the threaded parts of hydraulic unions, but not the mating faces. 1
Guest ozzie Posted November 14, 2015 Posted November 14, 2015 Here is a little hint for removing fittings with thread lock. Just heat them up. I used a steam cleaner with a pointy nozzle so it would just heat the fitting where it was needed also safer when fuel is involved. Heat softens the compound.
M61A1 Posted November 14, 2015 Posted November 14, 2015 If you use the correct thread locker for your application, it shouldn't be too hard to undo, and it will actually prevent galling and corrosion. 1
dutchroll Posted November 14, 2015 Posted November 14, 2015 It's fairly universally considered bad practice to use Teflon tape on threaded fuel fittings in aircraft (or even cars) and there are documented cases of tape shreds getting into fuel lines and carburettors. The Kitfox has an interesting service letter on fuel system fabrication which talks about the 25 fuel tanks sent out with Teflon tape incorrectly used on threaded fittings by the vendor. I agree it's very surprising to see it come out of a factory like that and wonder how intentional it is. 1
