shafs64 Posted August 29, 2015 Posted August 29, 2015 Was watching the so called news on channel 9 and they showed a spitfire replica. having a mishap at watts bridge. there word was it fell from the sky! but from the video it looks like if was landing of take off incident to me. shafs
XP503 Posted August 29, 2015 Posted August 29, 2015 Watched it whilst mid downwind. Looks like the right wing stalled on take off and it rolled steeply to the right heading for the crowd and flight line but I think maybe the wingtip dug in, so lucky it didn't roll inverted 1
Guest ozzie Posted August 29, 2015 Posted August 29, 2015 Looked like he had plenty of airspeed. Bit of control input may have helped. Sure he had the gust locks removed? Or maybe just a bit of fly in over amp? Should have sold this footage mate. Good stuff, you kept it all in frame!!
Bubbleboy Posted August 29, 2015 Posted August 29, 2015 Did he cut the engine before impact or was it an engine failure? Scotty
Guest Maj Millard Posted August 29, 2015 Posted August 29, 2015 That could have been a lot worse if he'd gone into the crowd...some speed there.
rodgerc Posted August 29, 2015 Posted August 29, 2015 Campbell Sharp's video make interesting viewing frame x frame 1
Tony Posted August 29, 2015 Posted August 29, 2015 Fantastic video Rodgerc ! Taking off the ground a Tail Dragger in 3 Point Landing Attitude and bouncing the Tail Wheel back on grass...........that great angle off attack on take off would not be too good for any light aircraft including Nose Wheel.
Tony Posted August 29, 2015 Posted August 29, 2015 Good point. I can't really see the r/h flap down. Can you ? 1
GAFA Posted August 29, 2015 Posted August 29, 2015 The aircraft appears to be in trouble just before it gets airborne. The left wheel leaves the ground first and the right wheel remains on the ground initially, before bouncing of the tail and right before coming airborne.Looking at the pilot you can see he is struggling to control the aircraft. There does appear to be lack of rudder movement, until just before the right wing touches the ground. 1
turboplanner Posted August 29, 2015 Posted August 29, 2015 We're the flaps asymmetric? Yes, RH flap wasn't down.
Guest Maj Millard Posted August 29, 2015 Posted August 29, 2015 Rolled right soon as it flew.......first flight ?........rego ?.
Guest Maj Millard Posted August 29, 2015 Posted August 29, 2015 Yes, RH flap wasn't down. That'll do it every time.
GAFA Posted August 29, 2015 Posted August 29, 2015 Have a look at 00:18 (post crash) and 00:56 (on the truck), doesn't appear to show any asymmetric flap. Spitfire's have a split flap, so given this is a replica I assume it has them as well.
turboplanner Posted August 29, 2015 Posted August 29, 2015 What counts was when it lifted off the ground Gafa; linkage could have been disconnected, loose.
GAFA Posted August 29, 2015 Posted August 29, 2015 Rolled right soon as it flew.......first flight ?........rego ?. Wasn't it's first flight, aircraft was flew into Brisbane last Saturday for the Aviation Careers Expo. Note, it was a different pilot in yesterday's accident.
Guest Maj Millard Posted August 29, 2015 Posted August 29, 2015 Lack of control input to counteract asamytric from prop at full power ?.....the real ones will do it if the airspeed is too low.
GAFA Posted August 29, 2015 Posted August 29, 2015 What counts was when it lifted off the ground Gafa; linkage could have been disconnected, loose. True, but both but at both of these times you can see the left flap and right flap position are the same. Post crash there would be no need (and the pilot wouldn't even think of retracting the flap post crash).So if there was flap asymmetry you would see the left flap down, which you don't. 2
turboplanner Posted August 29, 2015 Posted August 29, 2015 True, but both but at both of these times you can see the left flap and right flap position are the same. Post crash there would be no need (and the pilot wouldn't even think of retracting the flap post crash).So if there was flap asymmetry you would see the left flap down, which you don't. You can see it here.
GAFA Posted August 29, 2015 Posted August 29, 2015 You can see it here. Agree, that shows what appears to be the left hand flap extended. However in the photos I've attached you can see, when the flap is extended it runs along a lot of the wing, out past the replica gun and is mostly painted black and white. In the video (and the photo you have attached) the flap appears to be inside the replica gun and I can't see any black and white paint.) It could be the angle the video is taken from that that makes the right wing intake scoop (see first photo I've attached) make it look like a flap. My son took these photo as the aircraft taxiing out last week in Brisbane, but no flaps set. The second photo shows the aircraft parked in Brisbane with the flaps extended.
RV6JOY Posted August 29, 2015 Posted August 29, 2015 I expect if it is anything like scale it will have split flaps ie the top surface of the wing is fixed. What makes it look like plain flaps in the video is that the right aileron is down and the left up. Fact it took off tail down suggests it was too slow. Rudder should have been used to pick up the wing drop and may have been but unfortunately rudder position does not show in the video. Bad outcome, lots of money and work gone into that, hope damage is not too severe. 2
RV6JOY Posted August 29, 2015 Posted August 29, 2015 The image at the start of the video posted by RogerC certainly seems to show the left flap about 45degrees down but can't see the right flap. Not a good situation.
