Zlin T37, they originally built them with a radial. Looks to be a copy of an Auster Agricoler, There were a couple of the turbines in Unzud. They had a Walter turbine.
You got it, this one is in Unzud.
It looks like she was knocked up in a Russian Tractor factory. Nothing stylish, elegant or wind-cheating, about that cockpit design.
Typical eastern block country, I looked up Austers version of an Ag aircraft
Auster Agricola - Wikipedia
Looks very similar design to the Zlin, the Chek's took an outdated 50's design and decided to make in the 80's I think. With the Walter engine I think they were rated at a ton load.
Macchi M.B. 320. Powered by 2 Continentals (E185 models) rated at 185HP each.
Close, 2x 185 HP donks...lolol I guess the I-Mach rego gave it away???
Flighrite - I was trying to confirm if the Contys were 165HP or 185HP. Some sources say 165, some say 185. I think some typos have crept in, so I'll go with 185HP. The Italian lines gave it away. :cheezy grin:
You where quick on the 'edit' button....lololol
Try this one.
Try the yellow one from ONETRACK FIRST.
Man that's got some serious delamination going on there, sad?
That's what happens when you don't use enough duct tape! LOL
That problem canardly be fixed with duct tape.
  • Haha 2
Spot on with the Jihlavan KP-2U identification.
See here in the Showcase.
Well it’s a Ford Flivver so Mickey Mouse probably would have flown it
