OT is right, Platzer Kiebitz. Here is a photo of the same aircraft in flight. I was fooled by the cowling, but the undercarriage is the key. Bucker undercarriage is under the wing.
Platzer Kiebitz - Untitled | Aviation Photo #2129554 | Airliners.net
16 minutes ago, red750 said:
What aircraft is both a monoplane and a biplane?
A biplane that flies a little close to the underneath of a bridge ?
Where’s Flyboy ? He thought the Platzer was a Jungmann.
Similar, but different. And on this occasion, located around 20 mins flying time apart down the Rhein.
The monoplane/biplane is a Hillson FH40 Slipwing Hawker Hurricane. A Hurricane with a second wing which can be discarded after take-off. Designed to shorten the take-off for a quick scramble launch, then discard the top wing for speed for the pursuit and fight.
 r/Warthunder - Hillson FH40 Slip Wing Hawker Hurricane(yes it's a bi-plane Hurricane)
That seems a little wasteful, besides the risk of taking your tail off, I can't imagine many of the discarded wings tumbling down were able to be reused!
The upper wing appears to set higher than the tail, and providing lift with little weight, it would rise up clear of the tail after release.  The weight of the struts would prevent it flipping long enough to clear the tail.
Marty, the top wing was possibly made from a disposable cheap material, such as plywood.
Now that’s one way to ugly up a great looking plane!😂During a scramble I can see the airfield littered with splintered plywood, making A/C still taking off dodging the rubbish😂
CC, did you not check out the Aircraft directory on this website?
The PZL M-15 Belphegor is covered  in a profile.
57 minutes ago, derekliston said:
Designd by the same guy who did the Transavia Airtruck!!! (Kidding!)
BUT if they had not be directed to design around a jet engine (not suited to role) but instead allowed to use a turboprop this may have been a replacement for the AN-2  ... even though the AN-2 is now getting a turboprop.
Belphor or summit like that. A 70' span biplane pure jet, what a brilliant idea! The 2 hoppers might give some problems with emptying on solids giving a few asymmetric problems. They were that confident in the design that two seats were incorporated behind the pilot for an engineer an a joyrider 😁
11 hours ago, old man emu said:
Looks like a Tiger Moth stuck in a drainpipe!
