rankamateur Posted September 18, 2015 Posted September 18, 2015 Put one of these on it! Whirlwind razor blades on an AP430 Airmaster hub. 2
Guy s Posted September 18, 2015 Author Posted September 18, 2015 Thanks Steve, Do you know if Whirlwind have a agent in Oz or you deal directly with them in the US ?
rankamateur Posted September 19, 2015 Posted September 19, 2015 Airmaster deal with whirlwind direct, They fit the boss on the blade root that screws into the hub. It arrived ready to install 1
eightyknots Posted September 20, 2015 Posted September 20, 2015 [ATTACH=full]37998[/ATTACH] [ATTACH=full]37999[/ATTACH] She's bright That's looking nice, Guy. When will you get to pick up your Savannah?
Guy s Posted September 21, 2015 Author Posted September 21, 2015 That's looking nice, Guy. When will you get to pick up your Savannah? THE Fuselage is back at home if that's what you meant. When I pick up a finish part i leave the spray painters with more bit's to paint. It's been an on going slow process.
eightyknots Posted September 21, 2015 Posted September 21, 2015 THE Fuselage is back at home if that's what you meant. When I pick up a finish part i leave the spray painters with more bit's to paint. It's been an on going slow process. I suppose it is one step at a time, but you will definitely get there in the end! 1
Savannahflyer Posted September 22, 2015 Posted September 22, 2015 I read an earlier post that you where going to but the 912IS in your machine what made you change your mind?
Guy s Posted September 22, 2015 Author Posted September 22, 2015 I did have it in my heart to fit the 912is but when it came to the crunch the extra dollars for the motor and not really being able to use the exiting instruments and wiring that is supplied with the kit cause it's gear up for the ULS. So then having to go glass panel which I had intended but the work involve starting from scratch and the cost it seems I was starting to feel overwhelmed and opening a can of worms me thinks. Not to mention modifying the cowling to suit the 912is and also learnt that the return fuel lines would not cope with 912is and having already install the lines in the wing so it was all weighting against me and the extra time and brain matter to nut it out was becoming beyond me. Cowling and fuel lines would have been easy enough to change but the overall picture of the 912is was not. If the kit was catered for the 912IS then different ballgame. 1
Savannahflyer Posted September 22, 2015 Posted September 22, 2015 I had my heart set on the 912is as well I was hoping someone would of built one first. Lucky for me I haven't started the build so things like fuel lines I can tackle straight away. Mind you the extra out lay of $$$ for the engine itself plus the glass cockpit requirment is something to think about. I do like the idea of 14L an hour fuel burn though. 1
eightyknots Posted September 22, 2015 Posted September 22, 2015 I did have it in my heart to fit the 912is but when it came to the crunch the extra dollars for the motor and not really being able to use the exiting instruments and wiring that is supplied with the kit cause it's gear up for the ULS.So then having to go glass panel which I had intended but the work involve starting from scratch and the cost it seems I was starting to feel overwhelmed and opening a can of worms me thinks. Not to mention modifying the cowling to suit the 912is and also learnt that the return fuel lines would not cope with 912is and having already install the lines in the wing so it was all weighting against me and the extra time and brain matter to nut it out was becoming beyond me. Cowling and fuel lines would have been easy enough to change but the overall picture of the 912is was not. If the kit was catered for the 912IS then different ballgame. Yes, it would be nice if ICP would make a kit for FADEC/fuel injected style engines. That would cover the Rotax IS as well as some other alternative motors. Perhaps such a kit is not so far away?
rankamateur Posted September 22, 2015 Posted September 22, 2015 Yes, it would be nice if ICP would make a kit for FADEC/fuel injected style engines. That would cover the Rotax IS as well as some other alternative motors. Perhaps such a kit is not so far away? Are you sure it isn't already available? I am sure Reg told me the factory are now fitting 912iS and 914 motors. It is just not the standard 912S kit that he orders for stock. A kit is a pretty big investment in time and money so it is worth thinking it through and ordering just what you want. When I ordered mine, I ordered it with the extended rudder from the tail dragger version for a little bit more rudder authority. That had never been done before but Tom just specified a different order for that kit. Each kit is individual if you are prepared to wait 13 or 14 weeks for the delivery you can have what ever you want in the box. If you can't wait and there is stock here in Australia it will be 912S, extended baggage, long range tanks and cabin heat because they are the options that most people want. That rudder extension was a factory copy of the one Reg built on his maroon plane and also on the white/yellow turbo charged one he built. Just as they copied John Gilpin's VG idea, the factory aren't shy about incorporating improvements thought of by others.
eightyknots Posted September 23, 2015 Posted September 23, 2015 Are you sure it isn't already available?I am sure Reg told me the factory are now fitting 912iS and 914 motors. It is just not the standard 912S kit that he orders for stock. A kit is a pretty big investment in time and money so it is worth thinking it through and ordering just what you want. When I ordered mine, I ordered it with the extended rudder from the tail dragger version for a little bit more rudder authority. That had never been done before but Tom just specified a different order for that kit. Each kit is individual if you are prepared to wait 13 or 14 weeks for the delivery you can have what ever you want in the box. If you can't wait and there is stock here in Australia it will be 912S, extended baggage, long range tanks and cabin heat because they are the options that most people want. That rudder extension was a factory copy of the one Reg built on his maroon plane and also on the white/yellow turbo charged one he built. Just as they copied John Gilpin's VG idea, the factory aren't shy about incorporating improvements thought of by others. And the willingness to incorporate good ideas so readily, as you hinted Rank Amateur, is a good thing. This is a different approach to other manufacturers who insist on selling a particular feature with their aircraft even when it has been consistently shown that it is not the best thing for the mission it was designed for. I think it is often the designer's pride that gets in the way of adopting an obvious improvement.
Guy s Posted November 5, 2015 Author Posted November 5, 2015 Been a while since I've posted with a lighting strike hitting a tree in our yard and taking out the phone and 3 computers in the process, so here a few photo's of the progress which has been a little slow lately with a lack of time. Just started the wiring which I was never looking forward to and usually dos my head in but slowly nutting it out. Actually the wiring harness seems to be well thought out and not as scary as I thought. Cheers guy. 3
eightyknots Posted November 5, 2015 Posted November 5, 2015 Been a while since I've posted with a lighting strike hitting a tree in our yard and taking out the phone and 3 computers in the process, so here a few photo's of the progress which has been a little slow lately with a lack of time.Just started the wiring which I was never looking forward to and usually dos my head in but slowly nutting it out. Actually the wiring harness seems to be well thought out and not as scary as I thought. Cheers guy. Your "Dream Machine" is slowly taking shape. 'Onya' Guy. 1
dazza 38 Posted November 6, 2015 Posted November 6, 2015 Been a while since I've posted with a lighting strike hitting a tree in our yard and taking out the phone and 3 computers in the process, so here a few photo's of the progress which has been a little slow lately with a lack of time.Just started the wiring which I was never looking forward to and usually dos my head in but slowly nutting it out. Actually the wiring harness seems to be well thought out and not as scary as I thought. Cheers guy. Great workmanship Guy, well done.
Guy s Posted November 25, 2015 Author Posted November 25, 2015 Apparently you can't tint Lexan which I was hoping to do to the lexan that goes above your head to cut some of the heat and sun out. Now I was wondering if anyone has heard of Nightshade spray paint which you can spray on to give the lexan a darker look ?
fly_tornado Posted November 25, 2015 Posted November 25, 2015 I have some old 0.060" tinted lexan I pulled off my plane you can have for free, not very big though and its old. 1
Kyle Communications Posted November 26, 2015 Posted November 26, 2015 Apparently you can't tint Lexan which I was hoping to do to the lexan that goes above your head to cut some of the heat and sun out. Now I was wondering if anyone has heard of Nightshade spray paint which you can spray on to give the lexan a darker look ? Thats crap Guy whoever told you that. My Sav has been flying for 3.5 years and I tinted the overhead section and it is still perfect. if you look through the blog you will see it there with the parachute straps underneath it...I got it done by a car tinting guy at redcliffe...cost me 100 bucks as it was the best quality type and it needs to be put on by the experts and mine is still perfect. looks like its made like that 1
Guy s Posted November 26, 2015 Author Posted November 26, 2015 Thanks for the offer Fly_tornado. Rang a local car tinting mob and he said that when lexan gets hot it gives of a gas and plays havoc with the film and can also send it milky in colour. Will ring someone else Mark and cheers.
fly_tornado Posted November 26, 2015 Posted November 26, 2015 have you though about just using a blind? smoked poly carbonate so close to your head is still going to cook your brain in summer.
Kyle Communications Posted November 26, 2015 Posted November 26, 2015 Hi Guy I know I had to get a special type because of that reason thats why it was 100 bucks. I did a bit of ringing around until I found someone who actually knew what they were talking about. They are down at redcliffe I cant remember who they were as it was 4 years ago but will go down there in the next week or so and if they are still there I will get you the name. I wouldnt do it on the windscreen I did it so the sun wouldnt burn my bald head.....like someone else I know 1
Skee Posted November 26, 2015 Posted November 26, 2015 I bought 3m clear tint for front windscreen Cr90, and use a cr70 like tint for top screen. the car tinter guy had never seen such a clear window film. if you tint front screen remeber to tint it when folded, not flat. 2
rankamateur Posted November 26, 2015 Posted November 26, 2015 .....like someone else I know Yeah Yeah!!!
