Senator Xenophon stops the CASA regulations:
Part 145 Manual of Standards
And about time this happened with the disaster set of regs served up by CASA.
$250m and counting.
Then there is the $89.9m and counting from the continuing avgas/ avtur levy.
_______________________________________________________________________
The Disallowance Alert lists all instruments subject to a notice of motion for disallowance (whether at the instigation of the committee or an individual senator or member). The progress and eventual outcome of any such notice is also recorded.
http://vocasupport.com/senator-xenophon-stops-the-casa-regulations/
In fact, to interpret any of the regulation relating to specialist maintenance, at least five separate documents are required to be accessed and read.
You read your part 42;
You read your part 145;
You read your part 145 MOS;
Your read your part 66;
You read your part 66 MOS;
You read the guidance material;
You read the explanatory note for the guidance material;
You put your left foot in;
You take your left foot out;
You put your left foot in and you shake it all about;
I don’t see what the problem is....Seems pretty clear to me
Guest Maj Millard
This could be encouraging....what an arse backwards ballsed up system it is. They take the FAR guidelines from the US ( which work fine) and stuff them up so much that they will never work here...all the time keeping themselves in a job at our expense.
Doesn't Canberra exist purely to take sound principles, then totally screw them to the point where they cannot be applied? I was just reading an ATSB report on an ATC incident - total bollocks and full of pointless jargon. Smart country? Bah Humbug!
Unfortunately with the makeup of the current senate all it can do is block - nothing positive can be achieved - quite apart from whatever crap CASA is trying to push this particular time.
Xenophon - enough said.
  • Caution 1
