Great, but is solar a realistic alternative for aircraft?
Greater range than an extension lead would give you.
  • Haha 4
If they can stay up indefinitely then unmanned ones which can stay at say 60,000 ft may be cheaper than satellites for some things.
The Wright Flyer wasn't a realistic product at the time of it's first flight..... Standby to watch developments....
  • Agree 4
All these things are clever and interesting, but it's hard to envisage a level of energy concentration being available to lift a practical payload. Nev
Who cares if its impractical at this stage, the same things were said about early space flight...
Can we quantify the flow on effects of technology advancements out of the NASA space programs of the 60's and 70's?
What an absolute marvel of technology and engineering
  • Agree 3
I heard it's had a lot of forced landings at night ...... 003_cheezy_grin.gif.c5a94fc2937f61b556d8146a1bc97ef8.gif
Maybe it is one of those day VFR only recreational aircraft. 003_cheezy_grin.gif.c5a94fc2937f61b556d8146a1bc97ef8.gif
Run it on moonshine.
Al, the space programme didn't have a limit on the power it used. Sunlight has only so many watts per given area dependent on how far you are from the sun, and the angle you present to it.. Efficiency has only about a factor of 4 to go to 100%. OF course it is a wonderful creation as was the Gossamer Albatross which similarly was power limited by choice to ONE person pedalling Nev
With the advances in solar cell technologly we may soon see aircraft such as this running on sun power
- and it is aiming directly at our little corner of aviation!
There is a limit to solar. (as distinct from storage) You can get 100% in theory (maximum) with possible improvements ( and we have about 20% available now). You can concentrate it on the ground but not when the target is moving. The concentrated heat energy is dangerous (as it is when you use a magnifying glass). The Chinese have had electric powered aircraft for at least 3 years. Nev
I wonder why its maximum bank angle is only 5 degrees? Tight circuits would be challenging.
rgmwa
I believe this plane has 2 pilots so each pilot would be looking at the other ...................... seeing them as a 'payload'
Last night landing just before midnight. Batteries charged during the day sustain flight overnight. There are two pilots but only one on board at a time. It will need to stay aloft for several days when flying over the Pacific. Don't be too negative boys, just think how quickly technology has advanced in things like mobile phones and computers. I expect electric aircraft will be a real viable alternative in five or ten years.
  • Agree 4
Two pilots, but only one at a time. The other stays on the ground.
  • Informative 2
Run it on moonshine.Al, the space programme didn't have a limit on the power it used. Sunlight has only so many watts per given area dependent on how far you are from the sun, and the angle you present to it.. Efficiency has only about a factor of 4 to go to 100%. OF course it is a wonderful creation as was the Gossamer Albatross which similarly was power limited by choice to ONE person pedalling Nev
Hi Nev
I think the answer to making it practical is battery storage technology as that improves things will change look at model aircraft now they used to be all glo or diesel now it's electric .
I agree how far the storage of electricity has advanced. My comment though was specifically about the limitations of Solar by itself. Its a fixed level of energy ( without ,magnification). On the ground that's not so important, because with current technology a small part of the Sahara would power all of Europe, but for vehicles you need much more concentrated energy and it has to be portable. Nev
..., because with current technology a small part of the Sahara would power all of Europe, but for vehicles you need much more concentrated energy and it has to be portable. Nev
With Electricity it is always "Current" technology. ;-)
  • Haha 2
