Hi Would anyone have a copy of the CA21, Ca22 or Ca25 taildragger flight manual.
I am particularly chasing the CA21 & CA22 flight manuals.
Thanks
Mike
Sent Email to you Mike Regards Sue Wiggett
Guest 4aplat
Is it possible to get them too ?
thanks in advance
MicheL
Hi Mike l have a copy for my skyfox ca22 if you have trouble l could scan it and email it to you .
cheers Geoff..
Hi Geoff
That would be fantastic. I'll PM you my email address.
I have a CA21 and it was fitted up with a 912UL so its a bit of a hybrid. A sort of ca21 with 12 knot cross wind limit and the haul out performance of the ca22 with the 912UL.
Many thanks and will look forward to the copy. I really enjoy flying 606 and anly the constant rain and soggy grass airstrip has held my my solo.
Mike
Hi Geoff
Thanks very much for the copy it is a great help. I have rescanned it into one document so it may be helpful for your records. Hope to catch up some time.
Many thanks
Mike
Hi Mike it was a pleasure, is there much of a difference if any between the ca21 and ca22.
cheers Geoff
Guest 4aplat
Hi
thanks to Sandy that email me the Skyfox CA22 manual
I put it on my own server here
skyfox_ca22.pdf
and the one of the avid flyer
avid_MKIV.pdf
MicheL
Hi Geoff
I've just confirmed the flight manual for my CA21 is being registered posted to me tomorrow, when I receive it i'll let you know.
I don't think it will arrive before I leave for holidays so it may take two weeks to get the info to you.
Thanks again
Mike
Hi MicheL
The Sandy is my email replies. Thanks for the Avid info. I'm down loading it at present. I have the CA21 flight manual soon.
Mike
  • 1 year later...
Sue ,
do you happen to have a copy of CA 21 flight manual, I recently purchased a skyfox which unfortunately has the flight manual missing
Regards
Tom
Sue ,do you happen to have a copy of CA 21 flight manual, I recently purchased a skyfox which unfortunately has the flight manual missing
Regards
Tom
Hi Tom
If you do not get a copy from Sue let me know and i'll send you a copy. Send me your email address if requesting a copy.
Mike
Regards
Tom
Hi Plane maker has it got a 912 or the original areopower engine?
Mike
Hi Plane maker has it got a 912 or the original areopower engine?Cheers
Mike
Mike,It has the aeropower engine Regards
Tom
Mike,It has the aeropower engine RegardsTom
Hi Tom if you pm you email i'll end you a copy of the flight manual for 0606 for aero power engine if you want.
Mike
  • 6 months later...
Hi TomHave you any details of fitting a bolly prop to a p12 80ho in a Skyfox. I see Wigg mentioned being happy with the Bolly on thier gazzelle.
Thanks Mike
Mike, I have no information or experience with Bolly props, so sorry of not much help to you. I have a skyfox with original prop fitted. Tom
  • 10 years later...
On 11/03/2011 at 8:13 PM, Guest Wigg said:
Sue: Could you msg me please or post how to contact you thru this website.  I am now looking to replace my lost copy of a CA22 T/W Pilot Operating Handbook (POH or Pilot Notes or Flight Manual, as it is variously called).  Regards Carl
Sent Email to you Mike Regards Sue Wiggett.
Long time ago, but as my previous said re this matter:  I am after a copy of the CA22 T/W POH.  I don't need to be shy about posting my email address of [email protected] for initial contact.  An ecopy i.e pdf form or similar would be fine - docs in eform are now legal re required carriage. Regards Carl
  • 2 years later...
cheers Geoff..
Hi Cheers Geoff
Could you please send me that skyfox CA22
to me via email ?
If yes please send to my email
[email protected]
Many thanks for your kindness in advance
Tanapol.
Does someone have service manual for CA-22 or CA-25 tailwheel?
I can find only the once for CA-25N tricycle
