My VSI reads 200 fpm descent when it is level (ie even taxi ing along level ground) I find this annoying is this fixable or do I need a new one. Its a bit of a major job to get it out of the dashboard.
Dave
I think you need to say what kind it is..... Electronic? Brand? Coz to me, the VSI is more a mechanical gauge rather than "avionics".
Bah. It's still an instrument. :P
It's an odd thing, really. Where is your static sensor? For the VSI to indicate a descent, the pressure on the static port has to be steadily higher than the restricted hole in the case - as when you're descending. How is your altimeter behaving?
Of course it could be the needle is bent or something similar. Does the indication vary at all? -300fpm when you're doing a 100fpm descent, -100 when you're climbing at 100fpm?
If it's been dropped, perhaps that'd do it.
I have adjusted VSI's using the small screw on the bottom left of the gauge.
This is used to set zero. Really easy one minute job.
Look on the positive side David, if you roll over into a spin, you'll be much happier, even if only for a short time.
