Guest ozzie
just watched the shuttle lift off. wow what a machine. almost six and a half million pounds of thrust. (and here i am puttering around on 70lbs.) what a shame this has just about reached it's used by date. i wanna go!
ozzie
Guest Maj Millard
The big white clouds that come out from underneath the shuttle once the boosters ignite, are actually millions of gallons of salt water being vapourized by the booster exhaust nozzles. The big tanks of water underneath the boosters are there to absorb the shock of the ignition.
Nasa built another new shuttle launch facility at Vandenberg Air Force base in California. They were going to launch shuttles from that site. Instead of the big water tanks they had huge concrete pads sitting on huge springs, which were designed to not only absorb the ignition shock, but to also produce a little 'kick' effect at launch, which would have supposably increased the payload.
Although the facility was completed, it was never used because somebody forgot about all the nearby earthquake faults, which deemed it unsafe and unuseable !.
Another few US$ billion down the drain.
Have you watched a reentry and landing live on NASA TV Ozzie ??....magic stuff.
I have a mission patch from the first launch with Young and Crippen on board, totally experimental and nobody knew if it would work or not. That first launch had ejection seats fitted for Young and Crippen. The only one to do so. I still think it took huge gonads anyway.
:kboom:
The main engines on the shuttle are an incredible piece of human engineering and achievement. Here are some interesting facts about the engines.
Rocketdyne’s Space Shuttle Main Engine (SSME) operates
at greater temperature extremes than any mechanical
system in common use today. The fuel, liquid hydrogen,
is –423°F, the second coldest liquid on Earth, and when
burned with liquid oxygen, the temperature in the engine’s
combustion chamber reaches +6000°F – that’s higher than
the boiling point of iron.
The maximum equivalent horsepower developed by the
three SSMEs is just over 37 million horsepower.
The energy released by three of Rocketdyne’s SSMEs is
equivalent to the output of 13 Hoover Dams.
Although not much larger than an automobile engine, the
SSME high-pressure fuel turbopump generates 100 hp
for each pound of its weight, while an automobile engine
generates about 0.5 hp for each pound of its weight.
Even though Rocketdyne’s SSME weighs one-seventh as
much as a locomotive engine, its high-pressure fuel pump
alone delivers as much horsepower as 28 locomotives,
while its high-pressure oxidizer pump delivers the
equivalent horsepower for 11 more.
If water instead of fuel were pumped by the three
Rocketdyne SSMEs, an average family-sized swimming
pool could be drained in 25 seconds.
The SSME high-pressure fuel turbopump main shaft
rotates at 37,000 rpm compared to about 3,000 rpm for an
automobile engine operating at 60 mph.
Discharge pressure of an SSME high-pressure fuel
turbopump could send a column of liquid hydrogen 36
miles in the air.
Guest Maj Millard
Yes those are an interesting piece of gear, and have some degree of throttling. Once you light the solids, you are going somewhere Baby !!....there's no shutting them off.
I believe there is one of those turbo pump engines in the Powewrhouse museum ?.
I thought the Saturn 5 engines were the "best bang for you buck" but couldn't be used because they "weren't compatible" with the shuttle.
Guest ozzie
The Saturn V was overloaded with fuel when it was ignited it was still being fed fuel as it took several seconds for the engines to come up to power so it sat on the pad burning off the fuel until it could lift off ever so slow compared to the kick in the pants launch of the shuttle when the sbr's light. very spectacular they were.
