Guest Juliette Lima Posted October 17, 2008 Posted October 17, 2008 Hi All, At the risk of displaying some gaps in my Nav radio transmission awareness, I would appreciate some informed advice on radio protocol flying from YCNK-YTRE along the UL Lane when surrounds are restricted. We had some very infomative discussion some time back however Cessnock and Maitland CTAF frequencies have changed from 126.7 to 122.65. My query relates to appropriate frequencies entering, during, and departing the UL Lane.....I presume entering from the Maitland end would be 122.65 and soon after 126.7 ??? Look forward to correct procedures. Thanks in advance. JL
PaulN Posted October 18, 2008 Posted October 18, 2008 Hi JL, Me too, I'd like to know for certain. I plan to track that route southbound next Friday. Apart from 126.7 near YGCR I can only see that the area freq 120.55 is the go until nearing Maitland then broadcast an advisory on 122.65 and then off into the Newcastle CTAF area with 132.1. From my scan of the YWLM data in the ERSA I don't see any particular freq to use entering/during/leaving the GA lane. To err on the side of caution I'm inclined to give a position call on the area freq when entering and leaving the lane and probably another midway at Dungog when transitioning from 1500 to 1000. If I have this wrong can someone who knows put me right, please? Paul PS A word of caution ... anyone tracking this lane during Oct 24, 25, 26 be advised that there is a planned fly-in happening at Gloucester so traffic will be more than usual.
numptie Posted October 18, 2008 Posted October 18, 2008 Hi Guys, I'll have a similar issue today travelling the coastal route from Nobby's to Sugarloaf Point. Looks like I'll be on YMND CTAF, then around Beresfield 132.1 until I get to Willy CTAF airspace and then BN CEN up the coast. Should be a fun and scenic trip. I'll have to keep a keen eye out for other traffic, I imagine it's a fairly busy route. Sorry I don't have a difinitive answer for you both but I see Paul that we're thinking along the same lines.
Captain Posted October 18, 2008 Posted October 18, 2008 Numptie I've been studying both of those routes recently and the VTC says that on the coastal route you need the "Willy Clearance Delivery" on 130.35 both ways. On the inland route I can't see anything in the VTC or ERSA that contradicts what JL has deduced. But if anyone knows otherwise, let's hear it. Geoff
numptie Posted October 18, 2008 Posted October 18, 2008 I did see that but I thought it was only during tower hours, so I was going to check ATIS and if the tower isn't operating I didn't think I'd need it??????
Guest Juliette Lima Posted October 19, 2008 Posted October 19, 2008 Hi Paul,Captain,Numptie, Thanks for your replies....Have spoken to someone who flies regularly to Taree and beyond and he advises (as has been suggested here)....monitor Williamtown... advise Gloucester..... East of railway heading North.... West of railway heading South and necessary advisories fo Maitland and Taree. Thank you and cheers JL
PaulN Posted October 20, 2008 Posted October 20, 2008 Hey JL, Did your "someone" advise on which frequency to make those advisory calls, and importantly, is it safe to assume others know to use that same frequency to call and listen out? Paul
Guest Juliette Lima Posted October 20, 2008 Posted October 20, 2008 Hi Paul, Doubt that I could assume anything in respect of what others are doing. As Previously stated, I was informed advisory calls in the transit lane were not a requirement.....further,to monitor Williamtown during restricted times for the adjoining restricted areas.....monitor/communicate nearing Gloucester as you have suggested....advise Maitland leaving the lane South, and communicate with Taree CTAF when necessary. Sorry I can't provide any further info.....which is perhaps why I requested responses here. Cheers JL
slartibartfast Posted October 20, 2008 Posted October 20, 2008 Taree and Port Macquarie are both on 118.1 and the coastal route is quite heavily used, so I always make advisory calls on this frequency. Dick Smith considers Taree "the most dangerous airport in Australia", so keep a listening watch. You will also overfly Old Bar which gets a bit of use on weekends. The VFR lane is great fun, but if there is a westerly it can get very rough. If Williamtown is deactivated, the coastal route is much safer in these conditions.
motzartmerv Posted October 21, 2008 Posted October 21, 2008 Taree has an afru now.. Thats why rex grilled thier crew over that runin i had with them up there..http://www.recreationalflying.com/forum/incidents-accidents/7856-air-rage-rex-capt.html
