Hi everyone,
Since task saturation during the approach and landing phases is a constant topic in the general aviation community, I wanted to open a discussion about some new cockpit technology that recently received FAA NORSEE approval.
Holy Micro! LLC just announced the SkyVoice Alert 1000, which functions as an in-headset "digital copilot" to provide real-time, non-contradictory height callouts and aircraft parameter annunciations. What makes this unit particularly interesting for GA is its shift away from traditional single-sensor architectures.
Here is a breakdown of the technology and capabilities for discussion:
·         Triple-Sensor Fusion Platform: The system integrates an extended-range LiDAR, an internal Inertial Measurement Unit (IMU), and a precision barometric pressure sensor. By cross-validating telemetry across all three sensors in real time, the unit proactively detects and validates every flight regime—from ground operations and takeoff to final approach and rollout.
·         Expanded Height Awareness: It delivers precise Above Ground Level (AGL) audio callouts starting from 800 feet down to 1 foot during takeoff and landing.
·         Touchdown G-Force Intelligence: To provide objective post-touchdown clarity, the unit calculates and records peak vertical impact load factors at the exact moment of wheel contact. This gives pilots an immediate measure of touchdown firmness to help assess whether a precautionary maintenance inspection may be warranted.
·         Proactive Gear Warnings: To help prevent gear-up landing incidents, the system issues continuous, repeated "Check Gear" warnings during descent until the landing gear is verified safely down and locked.
·         Custom Context-Aware Reminders: Pilots can configure personalized audio reminders mapped to operational altitudes or run-times for key tasks like Checklist, LC GUMPS, Flaps, Speed, and Clearance.
·         Native CANaerospace Data Sharing: The unit can seamlessly stream real-time telemetry to external EFIS systems, glass cockpit displays, and remote annunciators.
From an installation standpoint, the regulatory path is quite streamlined. Because the unit is authorized under the FAA’s NORSEE policy, the installation legally qualifies as a minor alteration for aircraft certified under 14 CFR Part 23 or precursor regulations. Aircraft owners can bypass the lengthy and expensive Supplemental Type Certificate (STC) or Field Approval processes, as installation requires only a standard A&P logbook sign-off.
I’m curious to hear what the community thinks about the integration of IMU and barometric sensors alongside LiDAR for landing height annunciators. Also, how do you feel about having objective touchdown G-force data readily available after a firm landing?
Looking forward to hearing your thoughts.
