Hi,
I have a Rotax 912 ULS. / Dyon Skyview Class SV-ADAHRS-200, SV-EMS-220, with 2 Dynon EGT K Type Thermocouples/Probes PN. 100405-001
Today, on start up my EGTs were working fine.
Taxied out to runup bay and Number 1 EGT readout went blank & I received an EGT warning.
As I prepared to return to hanger, the EGT came good.
Went for a fly. Engine running just fine.
About 30min into the flight , EGT No 1 went blank again. Also had very brief/flash readings above Max EGT.
Retuned to airfield.
In situ, visual/external of EGT's leads/connections all look normal/good. Connections nice & firm.
Check resistance /continuity with multimeter. Both EGT's have continuity. No 1 resistance significantly higher than No 2. Unable to do a full check as engine still hot.
Will return tomorrow to do a ADAHRS diagnostic download & test Probes with heat gun
Do I have a EGT, Probe or ADAHRS problem?😈
Pretty sure I had to replace one of my Dynon EGT probes early in the piece, was reading off-scale-high at times. Easiest way to test to do is swap #1 + #3 probes to see if the problem follows the probe to #3. If yes, replace the probe. If the problem stays and stays at #1, run, do not walk, to your nearest pharmacy and purchase a tube of KY because it'll lessen the pain that's about to come.
Only two EGTs on #3 & #4.
Swapping EGT's on my installation, is technically  a "no brainer" but unfortunately very time consuming - I had hoped that someone else may have had similar symptoms of a failing thermocouple.
Does anyone find it interesting that the two EGT's have every diffident resistance readings?
You would expect the resistances to be the same merely because they are built the same. Having said that, a thermocouple is a temperature controlled voltage generator (ie at the point of the couple), not a temperature controlled variable resistor, so the actual resistance shouldn’t matter greatly (the input impedance of the measuring device will be comparatively very high). Regardless of that, ‘divide and conquer’  is your diagnostic friend. As kr said, swap them. There’s no cheaper (or more accurate) way to diagnose the fault.
