BrendAn Posted June 19 Posted June 19 A friend repaired my exhaust and I refitted it today. Looks good, sounds better. 2
skippydiesel Posted June 19 Posted June 19 May just be the photo but those exhaust springs dont look heavy duty enough or at the best angle/position, to keep the pipe in the muffler.  Whats the hose clamp for?  😈
BrendAn Posted June 19 Author Posted June 19 27 minutes ago, skippydiesel said: May just be the photo but those exhaust springs dont look heavy duty enough or at the best angle/position, to keep the pipe in the muffler.  Whats the hose clamp for?  😈 springs are under tension. slightly stronger than origonal. all nice and tight. there is a split in the collar that pipe goes into. i put the hose clamp on to keep it tight while i am ground running the engine. will taking it off to weld a new collar on before acr inspection. there is also a clamp holding carb heat muff up. when i fit the scat hoses i will put the screws back in and remove that too. 1
