A friend repaired my exhaust and I refitted it today. Looks good, sounds better.IMG20260619120520.thumb.jpg.678a3dabb721e044939cc6086336f5e9.jpgIMG20260619120529.thumb.jpg.7d8816444dbdd65e18c69ec54c1e9a4c.jpg
May just be the photo but those exhaust springs dont look heavy duty enough or at the best angle/position, to keep the pipe in the muffler.
Whats the hose clamp for?
springs are under tension. slightly stronger than origonal. all nice and tight.  there is a split in the collar that pipe goes into. i put the hose clamp on to keep it tight while i am ground running the engine. will taking it off to weld a new collar on before acr inspection.
there is also a clamp holding carb heat muff up. when i fit the scat hoses i will put the screws back in and remove that too.
