BrendAn Posted June 14 Posted June 14 i have a vdo tacho that is not working in the jabiru. it runs off a sensor on the flywheel. it has the inbuilt hour meter as well. Can anyone tell me if it can be repaired. it doesn't power up. i would hate to throw it out if its just a dry solder joint or something simple. a new one is $440 which does not bother me. its the loss of the recorded hours i would like to save. 2
T510 Posted June 14 Posted June 14 I have used Howard Instruments for VDO gauge repairs in the past.  They can be a little caustic and I know a few people who have had personality clashes with them but in my experience they do good work at a fair price. 2
onetrack Posted June 14 Posted June 14 There was a previous discussion around this same problem. The OP found a repairer in Adelaide. Â https://www.aircraftpilots.com/forums/topic/38510-vdo-rev-counter-hour-meter/#comment-531538 Â 2
BrendAn Posted June 14 Author Posted June 14 57 minutes ago, T510 said: I have used Howard Instruments for VDO gauge repairs in the past.  They can be a little caustic and I know a few people who have had personality clashes with them but in my experience they do good work at a fair price. i notice on this one the needle will flick up for a second when you apply power then its dead. and the hours don't come on. do think it might be just a power problem. 2
skippydiesel Posted June 14 Posted June 14 2 hours ago, BrendAn said: i notice on this one the needle will flick up for a second when you apply power then its dead. and the hours don't come on. do think it might be just a power problem. First off - Check cables for continuity and the that all joins are clean & secure . Pay special attention to the earth (-) return.  After the above, if it's still dead, you may need an electronics technician. Good luck! 😈  2
Thruster88 Posted June 14 Posted June 14 A Jab 55 here is having electrical issues, has been diagnosed as a bad fuse block. Tests fine until put under load. 1 1
BrendAn Posted June 14 Author Posted June 14 I have the tacho on the bench. I get nothing when I put power direct to the terminals. The problem is in the tacho itself. 2
Neil_S Posted June 14 Posted June 14 20 hours ago, T510 said: I have used Howard Instruments for VDO gauge repairs in the past.   I have used Howard Instruments for VDO tacho repairs too. They did a good job and charged a reasonable price. (Their shop is an Aladdin's Cave of instruments old and new!)  Cheers, Neil 1 2
BrendAn Posted June 15 Author Posted June 15 36 minutes ago, Neil_S said: I have used Howard Instruments for VDO tacho repairs too. They did a good job and charged a reasonable price. (Their shop is an Aladdin's Cave of instruments old and new!) Â Cheers, Neil Thanks niel
skippydiesel Posted June 15 Posted June 15 On 14/06/2026 at 5:19 PM, BrendAn said: I have the tacho on the bench. I get nothing when I put power direct to the terminals. The problem is in the tacho itself. Not an electronics person; My gut feeling is that just connecting the tacho to power, on the bench, is not a diagnostic action. To find out if the tacho is working you will need to send a pulse/signal (as from the flywheel sensor). You will first have to assertion that the sensor (Hall Effect/Photo/Lazer) is working as expected - probably the easiest way is to temporarily wire in a "know to be working" tacho. If the loner tacho works, then suspect your tacho but first follow my advice (above) on making sure you have good connections😈 1
BrendAn Posted June 15 Author Posted June 15 10 minutes ago, skippydiesel said: Not an electronics person; My gut feeling is that just connecting the tacho to power, on the bench, is not a diagnostic action. To find out if the tacho is working you will need to send a pulse/signal (as from the flywheel sensor). You will first have to assertion that the sensor (Hall Effect/Photo/Lazer) is working as expected - probably the easiest way is to temporarily wire in a "know to be working" tacho. If the loner tacho works, then suspect your tacho but first follow my advice (above) on making sure you have good connections😈 yes. but i thought putting power and earth to it should light up the hour meter. maybe not. i don't know anything about it. i think i will send it off and get it looked at.Â
facthunter Posted June 15 Posted June 15 Some work off an ignition lead by inductance. I doubt that would take kindly to a direct electrical source. Some Hobbs Meters work on electric power put through a U/C micro switch to Just measure AIR time. I have a good one IF anyone wants it. Nev 2 1
skippydiesel Posted June 15 Posted June 15 2 hours ago, BrendAn said: yes. but i thought putting power and earth to it should light up the hour meter. maybe not. i don't know anything about it. i think i will send it off and get it looked at. Give yourself the potential to save a few $$ - Check your sensor is working before, sending the Tacho for an expensive assessment😈 1 1
BrendAn Posted June 16 Author Posted June 16 23 hours ago, facthunter said: Some work off an ignition lead by inductance. I doubt that would take kindly to a direct electrical source. Some Hobbs Meters work on electric power put through a U/C micro switch to Just measure AIR time. I have a good one IF anyone wants it. Nev the vdo tach has a hall effect type pickup. the tach itself has pos and neg terminals and a sensor terminal. i would have thought putting power and earth to it would light up the hourmeter but as i said, i know nothing. 1 1
BrendAn Posted June 16 Author Posted June 16 i just found howard instruments right here in Hiedleberg. i will take it to them. 2
skippydiesel Posted June 16 Posted June 16 2 hours ago, BrendAn said: i just found howard instruments right here in Hiedleberg. i will take it to them. Let us know how things "pan out"😈
BrendAn Posted June 16 Author Posted June 16 Just now, skippydiesel said: Let us know how things "pan out"😈 will do
BrendAn Posted June 23 Author Posted June 23 On 16/06/2026 at 8:39 PM, skippydiesel said: Let us know how things "pan out"😈 spoke to howards yesterday. they are in the midst of moving to another building in Heidelberg hgts . the lady said bring the tacho in in 2weeks and they should be able to fix it. she also thinks its just a power issue because the hourmeter doesn't come on. 1
T510 Posted July 10 Posted July 10 On 23/06/2026 at 8:51 PM, BrendAn said: spoke to howards yesterday. they are in the midst of moving to another building in Heidelberg hgts . the lady said bring the tacho in in 2weeks and they should be able to fix it. she also thinks its just a power issue because the hourmeter doesn't come on. How did you go with this Brendan?
BrendAn Posted July 10 Author Posted July 10 2 hours ago, T510 said: How did you go with this Brendan? hi mate. no good so far. i rang yesterday and they said they couldn't possibly look at it til after the end of the month, after she had already told me they would look at it after 2 weeks. i decided to just get a new one from jabiru rather than wait and be told the same thing again. they are swamped with work at howards. jabiru can now get the hours programmed into the new tacho too which is something i wanted to do as well.    1
T510 Posted July 10 Posted July 10 That's disappointing, It's understandable that they are busy but they could at least give you an accurate timeframe. Â Â 1
facthunter Posted July 11 Posted July 11 How could you do that with a large backlog of work and not being sure till you start on each job how much work is involved or what parts are required and what can be repaired and can't be. ? The fact they have a lot of work means they are trusted. You're lucky to get people who are still doing this stuff at all. It's probably Not the way to make Millions either. In this world the retailer often makes more money per Item /article than the Manufacturer does. Nev 1 1
BrendAn Posted July 11 Author Posted July 11 2 hours ago, facthunter said: How could you do that with a large backlog of work and not being sure till you start on each job how much work is involved or what parts are required and what can be repaired and can't be. ? The fact they have a lot of work means they are trusted. You're lucky to get people who are still doing this stuff at all. It's probably Not the way to make Millions either. In this world the retailer often makes more money per Item /article than the Manufacturer does. Nev they are the vdo repair agents. you don't tell someone to come back in 2 weeks then in 2 weeks tell them the end of the month. i will buy a new tacho but i think i will still drop the old one off . see if they can fix that one so i have a spare.  1
facthunter Posted July 11 Posted July 11  I did explain the circumstances as I see them. I've run repair Businesses and know of many others where there Has been a waiting list or indefinite deferment. There is a limited capacity to handle stuff sitting around and keeping track of it. That all detracts from getting on with what you already have there already. No small business can be expected to cope with an unanticipated rush. Nev
