skippydiesel Posted 6 hours ago Posted 6 hours ago Anyone know where to source Tracy O’Brien brake parts (especially pads). 😈
Thruster88 Posted 6 hours ago Posted 6 hours ago If you ask google the correct question it can provide the answer AI Overview Yes, replacement brake pads for Tracy O'Brien C-90 hydraulic brakes can still be obtained, though the original primary website and storefront are now closed. Because Tracy O'Brien has transitioned or sold parts of the business, here are the most effective ways to source the pads: [1, 2] Direct Inquiry: You can still contact Tracy O'Brien directly via email at [email protected] to check the current inventory of replacement pads and Viton seals. [1, 2] Manufacturer Transfer: The tooling and inventory for some of Tracy O'Brien's designs were purchased by Experimental Aircraft Metal Fabrication, making them a prime contact for these specific parts. [1] Online Aviation Groups: Check specialized forums like the Sonex Aircraft Builders forums or dedicated Facebook groups such as Challenger Ultralight for second-hand sales or to connect with other builders. [1, 2] If you are comfortable sharing: What specific aircraft (e.g., Sonex, Challenger) these are for Whether you are looking for organic or metallic pads I can help you narrow down your search or locate other universal alternatives that fit your setup. 2
skippydiesel Posted 5 hours ago Author Posted 5 hours ago Wow!!!!! The question was asked on the Sonex Forum. I as a Sonex owner & user of TO'B brakes didn't know the answer and for future needs, thought I should. Thank you for the AI answer - be interesting to see how acurate/helpful it is.😈 1
onetrack Posted 3 hours ago Posted 3 hours ago The information supplied is likely to be riddled with errors, Skippy, and the AI generated answer will tell you, that there may be errors in the information supplied.
