sfGnome Posted 4 hours ago Posted 4 hours ago This thread is just a result of a diseased imagining in the early hours of the morning, but if it prompts some useful questions and discussion, then the restless night was worth it. 🙂 Imagine that you’re cruising on a long distance flight, say at 5500’, plenty of fuel, CAVOK, then the engine goes to wide open throttle and you can’t reduce it. What would you do? 1
facthunter Posted 3 hours ago Posted 3 hours ago At that Height the engine would be at about 75% Power so just climb a bit and keep going. Nev
Neil_S Posted 3 hours ago Posted 3 hours ago Hi SFG, Happened to my mate a number of years ago (throttle cable broke, I believe, and Rotax went to full, as it should). As Facthunter says, keep going. When at your destination (or a suitable airfield en route) conduct a circuit and then when certain of making the runway cut the engine and glide in to land. That's what my mate did and landed without any dramas. Cheers, Neil 1
Thruster88 Posted 3 hours ago Posted 3 hours ago In a "proper" aircraft one could use the red knob to control the engine. 1
BurnieM Posted 1 hour ago Posted 1 hour ago 1 hour ago, Thruster88 said: In a "proper" aircraft one could use the red knob to control the engine. Don’t proper engines have ECUs ? 1 1
skippydiesel Posted 41 minutes ago Posted 41 minutes ago IF ? you have a Constant Speed prop: Even if throttle cable broke, prop likly to remain at or close to, selected rpm. If above not true, select for courser pitch to govern rpm down to a less heart stopping rpm.😈
