Flu after the war, killed more People than WW1 did. Russia had a large number of deaths from Covid.  In a world where starvation is  common, some die from overeating ..Nev
2 hours ago, onetrack said:
 Pour the oil in the filter through a funnel lined with paper towel and let it drain for an extended period to see with better clarity, what was in the oil.
I like to pour a bit of petrol or diesel in to the filter to thin the oil and then run it through a coffee filter in a funnel, they tend to hold up better than paper towel
With a New Motor Cut the Filter open at the first Oil change. If metal evident try to work out why. Some new motors  can have swarf in them from inadequate cleaning before assembly. IF I found that I'd be dropping the sump and check all bearings and oil pump intake screen and let whoever supplied it Know and ask what they want done. You don't want to be caught far from Home and at the Mercy of the Local Mechanic..  Nev
What about using a paint cone filter?😈
You check what's in the Element mainly. Use a Magnet to sort out the steel and Iron particles  Wash the others with mineral turps or kero so you can see  better.. Like panning for Gold.
Motor has 1850 hours now. So not anticipating 'new engine' problems. Also, dry sump so not sure what the next step will be if there's large particles in the oil. But have a good workshop at the airfield to pick their brains or more likely if something serious, hand it over to them.
