danny_galaga Posted 13 hours ago Posted 13 hours ago Is this one ok? I anticipate using it once a year. And I assume it will work on a Rotax 912 filter? I don't have a filter onhand but from memory the Rotax is less than 5" https://www.aircraftspruce.com.au/catalog/topages/acsoilcancutter.php#
danny_galaga Posted 13 hours ago Author Posted 13 hours ago My second question is answered on the FAQ 😄 Q: Will the ACS oil can cutter cut Rotax filters? Yes, it will cut Rotax oil filters. 1
Blueadventures Posted 12 hours ago Posted 12 hours ago I use the AIRWOLF CAN CUTTER size for ROTAX FILTERS, sent you a pm as have a second one in its box package and never used. 1 1
Moneybox Posted 11 hours ago Posted 11 hours ago 1 hour ago, danny_galaga said: Is this one ok? I anticipate using it once a year. And I assume it will work on a Rotax 912 filter? I don't have a filter onhand but from memory the Rotax is less than 5" https://www.aircraftspruce.com.au/catalog/topages/acsoilcancutter.php# That's very expensive for a rarely used tool. I think I paid about $40 in Ebay for a similar tool and it does the job nicely. 1 2
onetrack Posted 11 hours ago Posted 11 hours ago (edited) I can't see where an oil filter cutter can be declared "aviation grade". An oil filter cutter is an oil filter cutter, regardless. Those prices are stupid for a simple workshop tool that never leaves terra firma. Edited 11 hours ago by onetrack 1
T510 Posted 54 minutes ago Posted 54 minutes ago I use a $15 cheapy, has worked well for years now 1 1
skippydiesel Posted just now Posted just now I'm amazed, all you guys with your cheepo, non aircarft certified, oil filter can cutter haven't YET been attacked by the aircraft certified, lest you fall out of the sky, only way to go, chaps.😈
