skippydiesel Posted December 3, 2025 Posted December 3, 2025 Automotive problem .  Way out of my depth - if there is someone who understands the following specifications, for a very small speaker/noise maker;  SPL (dB) Resonance  Frequency (Hz) Rated/Max Input Power(W) Impedance 90 dB at 1kHz, 0.2W, 0.1m Baffle (Sine) 430 0.2 / 0.4 45  Please contact me.  😈
FlyBoy1960 Posted December 3, 2025 Posted December 3, 2025 It’s a small speaker/buzzer that: Is fairly loud (90 dB at 10 cm) Works best around 430 Hz Should normally be powered at 0.2W, but can handle 0.4W briefly Has an impedance of 45 ohms
skippydiesel Posted December 3, 2025 Author Posted December 3, 2025 Thanks for all that FlyBpy1960,  My problem is that the existing "speaker" (specifications above) fitted to my car, only delivers a faint auditory indication of direction indicator operation (Clicker). I cant hear it when the window is open or the ventilation fan is on. The problem may be the speaker and /or my age. In the end it doesn't matter - I cant hear the indicator. I would like to find a speaker that is significantly lauder, that will not upset the cars computer ie will not draw significantly more amps for a higher volume. The existing speaker is a "UNIQUE" Model US-3750B Their range can be found here ; https://unique-sound.co.kr/products/.  "Unique Sound Co" is a Chinese company who do not wish to advise me on alternative speakers. I would be happy to fit a higher performing substitute or piggy back on existing speaker from any supplier.😈  Â
turboplanner Posted December 4, 2025 Posted December 4, 2025 1 hour ago, skippydiesel said: Thanks for all that FlyBpy1960,  My problem is that the existing "speaker" (specifications above) fitted to my car, only delivers a faint auditory indication of direction indicator operation (Clicker). I cant hear it when the window is open or the ventilation fan is on. The problem may be the speaker and /or my age. In the end it doesn't matter - I cant hear the indicator. I would like to find a speaker that is significantly lauder, that will not upset the cars computer ie will not draw significantly more amps for a higher volume. The existing speaker is a "UNIQUE" Model US-3750B Their range can be found here ; https://unique-sound.co.kr/products/.  "Unique Sound Co" is a Chinese company who do not wish to advise me on alternative speakers. I would be happy to fit a higher performing substitute or piggy back on existing speaker from any supplier.😈   It's a mandatory requirement to provide a light which flashes, which caters for those losing their hearing. Sometimes you have to adapt to the equipment.
KRviator Posted December 4, 2025 Posted December 4, 2025 Two of these little buzzers should do the trick. Wire one of each in parallel with the quarter-panel-mounted indicator. If you leave the left side one on the left side of your glovebox or that general area, you'll even have a '3D' indication as to what blinker you have selected.
onetrack Posted December 4, 2025 Posted December 4, 2025 (edited) Skippy, the website link you provided is a Korean manufacturer site, not Chinese (and your link doesn't work because you included a full stop in the address). The reason they are refusing to provide any advice on speaker upgrades is because the site is a manufacturer site, and the page is only providing specifications of their products, it's not a "shop" page where you can buy items or get advice. They will only reply to large businesses seeking to order high volumes of their product.  https://unique-sound.co.kr/products/ Is the speaker in your VW or Audi? I guess you're looking for an alternative replacement, due to the "European manufacturer tax"? (i.e. - high parts prices).  The Chinese are your friend, they can supply the US3750B, plus they can supply a US3750C alternative. Unfortunately they provide no specifications for either buzzer, you will have to email the seller, and ask for the precise electrical specs. However, if you check the Korean manufacturer site again, the specs are there for the US3750C they manufacture. I would presume the Chinese specs are identical, but it would pay to check.  The only problem I see, is the US3750C produces sound at a higher frequency (870Hz VS 430Hz for the US3750B) - and as you age, high frequencies are the ones your aging ears fail to pick up.  I'd suggest the major problem with your original buzzer is that it has simply weakened with age, and no longer produces sound levels to the original specifications.  https://www.aliexpress.com/item/1005010041259835.html?gatewayAdapt=4itemAdapt#nav-specification  https://www.aliexpress.com/item/1005008216109531.html#nav-specification  Edited December 4, 2025 by onetrack 1
skippydiesel Posted December 4, 2025 Author Posted December 4, 2025 1 hour ago, turboplanner said: It's a mandatory requirement to provide a light which flashes, which caters for those losing their hearing. Sometimes you have to adapt to the equipment. Just like in aircraft applications - keep your eyes OUTSIDE when ever possible. That's why an auditory indicating AND a visual are supplied.😈 2
turboplanner Posted December 4, 2025 Posted December 4, 2025 While I agree with loud turn indicators because they alert you to any tendency to stay on, here's a resiult despite the very loud Gear Up warning in a 182. Â Â These two were distracted, note the VERY late turn on to Final, then the immediate need to lose a lot of altitude, and at the same time not registering the loudest warning in the aircraft. 1
skippydiesel Posted December 4, 2025 Author Posted December 4, 2025 (edited) Yes well - nothings perfect and if something can go wrong, a human will find a way to achieve it.  Fortnightly leaving my indicators on, way past their intended signal of a maneuver, is not quite in the league as gear up landing.  I have discovered my problem with a faint auditory indicator signal is not unusual - while other have writen about it non seem to have come up with a solution (YET!).  Was a time, not so long ago, when I would just replace the flasher cylinder/cube. Quick, easy, cheap solution made unnecessarily complicated by the vehicles computer management system PROGRESS??????😈 Edited December 4, 2025 by skippydiesel 1
Moneybox Posted December 4, 2025 Posted December 4, 2025 Skippy, I'm not familiar with a speaker type indicator. Flasher relays used to have the clicker built in. To make it more easily heard it needs to be mounted onto a metallic surface that will transmit the vibration.  Have you ever had one of those styrene lunch boxes we used to get and had it touch the gearstick. It sounds like your gearbox is dragging on the ground. 1 1
skippydiesel Posted December 4, 2025 Author Posted December 4, 2025 Forget all the electronics - This looks about doable at my level of understanding.😈 https://infinitybox.com/wiring/makin...-signal-noise/ I 1
onetrack Posted December 4, 2025 Posted December 4, 2025 (edited) That's all well and good - but you supplied specific dB, Hz, Power and Impedance figures in you first post - but this relay you've found, has absolutely zero information, as regards any of those specifications?? Â How do you know this relay produces a sound that you can hear? "Clicks" is not exactly a definitive physics or electrical specification. Â What is worse - the link provided to the product on the Waytek Wire website doesn't work. So, I pull up the photo of the relay, get the P/No off it - type that into the Waytek Wire search menu - and it comes back, showing the relay, with the advice, "this item has been discontinued". Â https://www.waytekwire.com/product/te-connectivity-v23234-b0001-x001 Where to now, Batman?? Â Edited December 4, 2025 by onetrack
skippydiesel Posted December 4, 2025 Author Posted December 4, 2025 11 hours ago, onetrack said: That's all well and good - but you supplied specific dB, Hz, Power and Impedance figures in you first post - but this relay you've found, has absolutely zero information, as regards any of those specifications??  How do you know this relay produces a sound that you can hear? "Clicks" is not exactly a definitive physics or electrical specification.  What is worse - the link provided to the product on the Waytek Wire website doesn't work. So, I pull up the photo of the relay, get the P/No off it - type that into the Waytek Wire search menu - and it comes back, showing the relay, with the advice, "this item has been discontinued".  https://www.waytekwire.com/product/te-connectivity-v23234-b0001-x001 Where to now, Batman??  Hi Onetrack,  Be not concerned.  Fact - I am very very uncomfortable with electronics. The InfinityBox solution, proposed on another Forum, is about my level of understanding. I have several preloved relays, sitting around, that I can experiment with. Even if non of the relays make a sound, I think I can see how a small speaker/buzzer might be connected, that might - its a line of investigation.  My thanks to you and all the above who contributed.😈     1 1
cherk Posted December 5, 2025 Posted December 5, 2025 The additional load of the relay on the module MAY slow the rate of 'blink' ! 🥴
skippydiesel Posted December 5, 2025 Author Posted December 5, 2025 Just now, cherk said: The additional load of the relay on the module MAY slow the rate of 'blink' ! 🥴 Hopefully not, as the amps required to operate (open /close the circuit) is usually very low. 😈
facthunter Posted December 5, 2025 Posted December 5, 2025 Blink rate is usually greater when more Load in the circuit ie More lights involved . Most have NO relay and have Indicator Lights on the dash. Various self cancelling methods are used to you don't look like a Blinking Idiot. Nev 1
cherk Posted December 6, 2025 Posted December 6, 2025 My experience has been ie:  replace incandescent bulbs with LEDs , the blink rate (frequency) goes up rapidly and requires additional (resistive ) load to slow the rate DOWN to acceptable levels . YEMV ! 🤔 1
facthunter Posted December 6, 2025 Posted December 6, 2025 Depends on the Mechanism. A Bi metal strip will behave as I have described. Nev
