Lyndon Posted November 27, 2025 Posted November 27, 2025 After researching and talking to suppliers I'm still not convinced what to order Any advice??? My number one pick is the GA35 at this point. There is also a cheaper option that sits on top of the instrument panel. Someone who has been down this road, your advice would be a great help. It's not IFR, has a G5 and a GtX45r and of course the G3. Thanks Lyndon
BurnieM Posted November 27, 2025 Posted November 27, 2025 The GA35 is designed for external mounting but dash mount antennas seem to work fine too. I believe you need 3 GPS antennas; G3X Touch G5 and GTX45R.
Lyndon Posted November 27, 2025 Author Posted November 27, 2025 I have the transponder for the GTX. That was simple. The G5 has nothing? Just confused with what to buy for the G3X. Lyndon
BurnieM Posted November 27, 2025 Posted November 27, 2025 (edited) The GA35 is a good antenna and a little more robust than the dash mounts. Maybe you can get away without a G5 antenna. Comments from Vans forum; https://vansairforce.net/threads/garmin-g5-external-gps-antenna-needed.160538/ I'm a little confused on the GTX as the GTX45R is a transponder. Do you have the model with the internal GPS or are you using a GPS20A (seperate GPS receiver). Does this come with an a GPS antenna in the box ? Last time I looked you needed to purchase a GPS antenna and an ADS-B antenna separately (but this was a while ago). Edited November 27, 2025 by BurnieM
Lyndon Posted November 27, 2025 Author Posted November 27, 2025 I think the GTX has it all inbuilt. Only one connection for an XPDR anttena Lyndon
BurnieM Posted November 27, 2025 Posted November 27, 2025 (edited) 9 minutes ago, Lyndon said: I think the GTX has it all inbuilt. Only one connection for an XPDR anttena Lyndon If you have only a single antenna mount (for ADS-B) on the GTX then it sounds like you do not have an internal GPS. You need a GPS source for ABS-B otherwise the GTX45R will only work as a mode S transponder. An IFR navigator (like a GTN650Xi) or a GTX internal GPS or a standalone GPS (like a GPS20A) is needed with the GTX45R for ADS-B. The internal GPS on the G3X Touch cannot be used as an approved GPS source with a ADS-B transponder. Edited November 27, 2025 by BurnieM
Lyndon Posted November 27, 2025 Author Posted November 27, 2025 It has a built in wass and GPS apparently Lyndon
BurnieM Posted November 27, 2025 Posted November 27, 2025 There are two models of GTX45R. If it has an internal GPS it should have 2 antenna sockets on the rear and it needs both a ADS-B antenna and a GPS antenna.
