BrendAn Posted June 29, 2025 Posted June 29, 2025 i remember a gas turbine backup generator on a minesite, somewhere in the goldfields. they had to make a tunnel of scrub in front of it with sprinklers , like a coolgardie safe. apparently it would not work properly with 45 deg heat going into the intake. 2
Geoff_H Posted June 29, 2025 Posted June 29, 2025 31 minutes ago, facthunter said: Theres a lot of high temp exhaust with Turbines . They are ALL Carnot Cycle and the efficiency is a result of high Combustion Temps and PRESSURES. I've NEVER seen any what you would call HIGH pressures in an aircraft jet engine and you only get IT at near PEAK REVS. Highest I've seen is an EPR of about 2.3. That's AXIAL flow . Multiple Stage, centrifugal ones could go higher but I know of NO examples. Turbines operated at Low Power and altitude have abysmal efficiency and non fan Turbines are a thing of the Past, in aircraft. Also like Many Turbo chargers they can quickly ruin your Hearing. Some LARGE Jet Aircraft engines HAVE been used in the ME to generate electricity but they sit on Lakes of OIL. They can be fired up and at full Power within Minutes. Pistons still remain the Most efficient Dinasaur derived Power Plant but their reliability Borders on Unacceptable some times.. Nev The smaller mines use 5MW diesel generators. But most large mines use GTs. Usually S&L GE aircraft derived 50/60MW with gearboxes to generators. A few Trent 70's exist and there redesigned to stationary generation rather poor (Rolls Royce aircraft derived). But most new installations are purposely generation designed GT'S of 100MW and combined cycle with steam turbines using Heat recovery (GT exhaust) steam generators and steam turbines 60%+ efficiency. GE have a steam cooled first stage turbine design that is rumoured to have 60% efficiency. Aircraft derived engines are not favoured for power generation as gearboxes above 60MW don't seem to exist. Power generation GTs run at 3000/3600RPM. However the GT that I worked on had Pratt and Whitney aircraft designed blades made under licence. Power Generation GTs of 400MW are now reasonably common. 2
Geoff_H Posted June 29, 2025 Posted June 29, 2025 11 hours ago, BrendAn said: i remember a gas turbine backup generator on a minesite, somewhere in the goldfields. they had to make a tunnel of scrub in front of it with sprinklers , like a coolgardie safe. apparently it would not work properly with 45 deg heat going into the intake. Yes water cooling of the inlet air is common on stationary GTs. The compressors are density sensitive and produce less powe as the density drops. S&L GE aircraft derivatives are rated at around 60MW, but derated to around 50MW in the Goldfields. Super pure water is often injected just before the combusters. Is converts to steam (a steam turbines effect) and cools the combusted exhaust gas and allows more fuel to burn and a consequential power output. Some aircraft also do this to compensate for air density power loss in hot environments on take off. Super pure water is expensive to make so water injection is only used when an increased power is needed, or in power generation to the grid makes it economic. Walnut shells are often used in the air to clean blades. 3
Siso Posted June 29, 2025 Posted June 29, 2025 The company I work for have some Olympus (concord) gas turbines and have no gearbox. The engine is used as a gas generator and they run another turbine in the exhaust stream that connects to the generator. 3
Siso Posted June 30, 2025 Posted June 30, 2025 The advantage of the aircraft derivatives for power generation is their extremely fast starting.
Geoff_H Posted June 30, 2025 Posted June 30, 2025 Yes the speed of load rise depends upon the thermal inertia of the casing and the allowable rate of temperature rise. Derivatives are great for up to around 70MW. A 200MW stationary can get to 70MW around the same as a derivative (most stationary GTs meet the 10 minutes cold to full load). Below 60/70MW derivative makes the most sense from a cost point of view. Stationary GTs can quickly increase the load using water injection etc. Also stationary can immediately alter the set point on first stage inlet temperature, an increase in temperature instantly increases output at the cost of blade life. In a micro grid you always have enough reserve power to immediately replace the loss of the power being generated by the biggest loafed GT.
