skippydiesel Posted March 24 Posted March 24 Having a bad trot with my ADAHRS. Wondering if anyone else in Au experiencing similar. Original (first) module worked perfectly for aproximately 130 hrs Failed without warning, on ground, on pre engine start check. Cable continuity checked and found to be good. Loan module worked perfectly for about 5 hrs - Replaced, still working, when new (not remanufactured) module arrived. No explanation from Dynon as to reason for OM failure. New module had initial problems (frozen compass) - Fixed by belated download/update New module worked faultlessly for about 4 hrs New module failed on ground, on pre engine start check. Dynon sending a loaner module, hope to install today Note: First module failure , turned whole electrical system off several times - red cross & failure message appeared each time Second module failure, as above, however each time normal screen appears but only remains for about 30 seconds, before reverting to red cross & failure message. 😈
rodgerc Posted March 24 Posted March 24 Might be worth chatting to David Brown in Brisbane. david at candoitaustralia dot com dot au
skippydiesel Posted March 24 Author Posted March 24 (edited) Thanks Rodgerc - have emailed him😈 Edited March 24 by skippydiesel
skippydiesel Posted March 24 Author Posted March 24 3 hours ago, rodgerc said: Might be worth chatting to David Brown in Brisbane. david at candoitaustralia dot com dot au Email address not good - got another?😈
KRviator Posted March 24 Posted March 24 What's the failure message? That "Multiple Sensors failed" type thing can often be caused by attempting to do a pitot-static check without being in test mode, the ADAHRS sees the rapid climb/descent and IAS changes without corresponding GPS position or accelerometer changes and cries foul. Doesn't sound like you've actually done a P-S test, but it might be somewhere to start. First thing I'd do is unplug your GPS antenna, do a network calibration to rediscover all the modules but without the GPS, cycle power and see what happens. 1
rodgerc Posted March 24 Posted March 24 3 hours ago, skippydiesel said: Email address not good - got another?😈 Sent you a message
skippydiesel Posted March 25 Author Posted March 25 Had a great chat with David Brown - certainly knows his Dynon (& other) systems inside out.😈 1 1
skippydiesel Posted March 25 Author Posted March 25 Latest ADAHRS fitted - off to the airfield to do the compass calibrations. 1
skippydiesel Posted March 26 Author Posted March 26 Done! Compass ground & air calibrations - 127%✔️ A of A also done but need to consult on when low speed warning comes on - currently at 50%😈 1
skippydiesel Posted April 5 Author Posted April 5 ADAHRS out again - same symptoms as before - worked perfectly on last flight, turn system on, screen comes up normally for about 30 seconds , red cross comes up, ADAHRS sensors failed.. This time did a "forced load" - ADAHRS back as if nothing had happened??????? Have written to Dynon/Horsham - won't hear back until Monday Any of the electronics "wiss kids" got any suggestions/answers😈
Underwood Posted April 5 Posted April 5 Maybe the Dynon instrument itself has a problem (vibration/heat buildup?) I'm chasing multiple problems with an MGL unit right now and its a nightmare. 1
3rd harmonic Posted April 6 Posted April 6 Hi Skip, It would appear logically that after multiple different units being installed/uninstalled the original issue may not have been resolved... I would be looking specifically at the grounding and or negative return to the battery. Some bits of gear will do all kinds of funny things when the ground is lost, intermittent or high impedance. If the main ground which is on the DB37 connector (I think) is faulty then current may be making its way back via the shields on the data Comms connections causing corrupted data. A 4-wire ohm meter is the weapon of choice to do this that can accurately measure fractions of an Ohm (egg 0.01) Check the plug, pins and crimps. With the plug disconnected and no power applied, check the resistance back to the battery. Aggravate, vibrate, tap things while doing these resistance checks If the resistance changes or goes higher than 0.5 ohms then that could cause those issues... It's a bit hard to explain exactly how to go about this, but hopefully that gives you some idea... 2 1
sfGnome Posted April 6 Posted April 6 1 minute ago, 3rd harmonic said: Aggravate, vibrate, tap things An engineer’s most important tool - aka ‘percussive maintenance’. 1 1
onetrack Posted April 6 Posted April 6 Faulty connections, corroded connections, damaged plugs and connectors, these are all the nightmares of electrical/electronic trouble-shooting, and they can take a long time to pin down. It's a steady process of elimination.
3rd harmonic Posted April 6 Posted April 6 I have seen D connectors where the pin has been pushed back into the plug. In my context that is 8 channels of balanced audio on a DB25 using the TASCAM pinout - a faulty pin can result in losing half or 6dB of the signal, either the +hot or -cold. Looking at the Dynon installation manual and DB37 connector pinout there are 2x V+ power inputs (pins 1 and 20) and 4x ground pins (pins 21, 22, 23 and 24) for redundancy. Power and ground are right next to each other and the pins are also pretty close inside D connectors and it is very easy for even a single strand to come adrift and create an intermittent short circuit which could easily generate the funny resets ect I would open up the back shell on the DB37 plug and check that as a first port of call... 1
skippydiesel Posted April 6 Author Posted April 6 Dynon have asked me to; Disconnect the ADAHRS Check pin 2 & 7 Report finding to 1/0 of an ohm 1
skippydiesel Posted April 18 Author Posted April 18 Update: With Dynon /Horsham on phone (not all the time) have disconnected/reconnected modules & engine sensors, checked V in all configurations - everything checked out with the correct voltage System going down in same circumstances as before - now just turn off system. Go do something else for a few minutes. Turn back on - all good. So far system has worked flawlessly in the air. Have downloaded Diagnostic Export & sent to Dynon USA. Hope to have something back from the experts next week😈
Underwood Posted April 18 Posted April 18 I'm sure you've checked this already but does the problem track voltage on the bus?, I mean is happening when you have lower voltage?
skippydiesel Posted April 19 Author Posted April 19 20 hours ago, Underwood said: I'm sure you've checked this already but does the problem track voltage on the bus?, I mean is happening when you have lower voltage? Sorry I don't follow -When would I have lower voltage? Just back from Holbrook Fly-In - with the exception of an odd random fuel pressure drop, on the way home, Dynon/aircraft worked flawlessly😈 1
Moneybox Posted April 19 Posted April 19 I'm not and electronics person, good old electrics for me, that I understand however I've experienced poor earthing and inductance as the most common faults I've had to deal with. You have a plastic plane therefore everything must be return earth because the mounting points for many things are not necessarily to metal. You only need one loose earth to cause fluctuations in current flow. If you have two cables running parallel the current draw from one can upset the other. Amateur opinion here but I have delved into a few sticky little issues from time to time. 1 1
skippydiesel Posted April 19 Author Posted April 19 I am a big believer in having dedicated earth (-) return lines on all 12V systems. I think I should revisit the earth return buss and make sure all connections are clean & tight. The Sonex is almost all metal - earth return lines installed and connected to airframe. I confess I did not do this for the wing tank level sensors - something to fix in the future,😈 1 1
skippydiesel Posted July 23 Author Posted July 23 UPDATE on Dynon problem. Horsham Aviation may have solved my Dynon ADAHRS repeating failure. On advice from LAME, I disconcerted my Pitot/Static/ A of A tubes from the ADAHRS module EUREKA!!!! system immediately worked correctly. One or more tubes would seem to be partially blocked confusing the ADAHRS electronics. I blew out all three tubes, using a 12V compressor - no indication of back pressure. Re attached all three tubes - system continues to work. Such a simple fix, after many months of complex testing, diagnostic downloads & about 4 replacement ADAHRS modules and one loner SV (screen). In the past the system has failed at between 3-6 Hobbs hours, so it will be interesting to see if I can get past this pattern. Living in hope!😈 2
