sfGnome Posted January 9 Posted January 9 Well, I’ve just ticked over 1000 hours building, and that’s just the time in the shed. All the hours on the computer investigating options and sourcing parts are not included. Probably about another 1000 to go. Funny thing I noticed yesterday. With the heatwave, it appears that all my heat shrink tubing has shrunk a little. The size that used to slide over a spade connector now just doesn’t. Now all I need is for the heat to help my gut to shrink a little… 😛 1 6
Moneybox Posted January 10 Posted January 10 12 hours ago, sfGnome said: Well, I’ve just ticked over 1000 hours building, and that’s just the time in the shed. All the hours on the computer investigating options and sourcing parts are not included. Probably about another 1000 to go. Funny thing I noticed yesterday. With the heatwave, it appears that all my heat shrink tubing has shrunk a little. The size that used to slide over a spade connector now just doesn’t. Now all I need is for the heat to help my gut to shrink a little… 😛 I've found it better to buy the multi layered heat shrink from someone like MM Electrical, an electrical wholesaler. It seems to have a resin or something in there so it not only shrinks but seals and bonds as well. Not easy to remove but I don't usually want to pull my soldered joins apart. It stays tubular as well unlike some of the cheap stuff that flattens and kinks easily. 4
sfGnome Posted 10 hours ago Posted 10 hours ago Ok, here's a strange one for all you Savannah (and possibly Zenith?) people. I put a bit of fuel into each wing today for the first time - plenty sufficient for it to flow into the header tank - and it didn't. I spent about 15-30 minutes mulling this over and checking what I could without starting to undo pipes, and eventually I gave up thinking and pushed it back into the hangar. Hey presto, the fuel was in the header. Something about moving it started the flow, and then it flowed quickly as you'd expect. Interested to see if it was a blockage that had somehow moved, I pushed it outside and repeated the process. Again, no flow until the aircraft was moved, whereupon it flowed. Have you seen this? Is this a normal Savannah thing? I expect that if the header tank and pipes were full, it would not happen (ie fuel would flow as it was consumed), but I'm having difficulty making sense of it. 2
Kyle Communications Posted 10 hours ago Posted 10 hours ago Does your header tank have a breather at the top?...The std Sav setup is wrong so you can get a vapour like lock. I only have all tanks feed into one pipe at the top of the header tank..the other entry at the top I do NOT connect to the plumbing system it goes to the top of one of the tank sides to act as a breather/normalizer so flow will alwys happen 2 2
facthunter Posted 10 hours ago Posted 10 hours ago Might be worth checking your flow rate as you did initially. Sediment can settle in the Lower parts of the fuel Lines. Perhaps disconnect sections and blow out with compressed air. When you cut a section of rubber fuel line be careful there is Not a section (scarf) that can obstruct fuel flow.. Lodge in some Place. Nev
IBob Posted 9 hours ago Posted 9 hours ago 13 minutes ago, Kyle Communications said: Does your header tank have a breather at the top?...The std Sav setup is wrong so you can get a vapour like lock. I only have all tanks feed into one pipe at the top of the header tank..the other entry at the top I do NOT connect to the plumbing system it goes to the top of one of the tank sides to act as a breather/normalizer so flow will alwys happen Mark, by the time my kit was despatched in Dec 2014, ICP had corrected that, with instructions to connect the header with a breather, as you describe. 2 1
sfGnome Posted 7 hours ago Posted 7 hours ago Yep, there's a breather on the top of the header that goes to the top of the LH tank.
Kyle Communications Posted 4 hours ago Posted 4 hours ago Gnome if you do have a breather only pipe in the top of the header tank then it can only be that you have a low loop in your fuel hose. It basically has to run uphill at some stage to get from the tank to the header tank...this is the laws of physics. Every liquid will run down hill....so if it doesnt there must be some wierdo blockage. I did have a issue in the first few months of my aircraft that there was a intermittant blockage that was draining the carb bowls at high power. I finally found that a piece of plastic had come off the inside of the tank it was not a shaving it was a flat flake and it got lodged in the bend of the alu tubing that ran under the floor and upo to the firewall and it slowed the flow to my gascolator. It would be hard to imagine both tank feeds to have something like that. There must be a simple answer to the issue. I would have to look through my original XL build blog on here to find the pictures of my header feed system.... oh just had a thought before finishing this post...are the breathers on you tank caps working?...this could also be a issue if they are not doing their job or restricted. I got rid of the silly 3mm tubes from the fuel caps through the wings and used 6mm alu tubing in the tank caps. You will find a post on my blog why I did this...I couldnt access a full tank of fuel due to a insect getting into the 3mm breather tube
