BrendAn Posted May 13, 2024 Posted May 13, 2024 6 minutes ago, Flightrite said: Rollo with a 120 HP donk that should make the pup just about perfect👍80 Hap I consider under powered, a Rotax 200 gee gee would be the sweet spot👍 Shame about the SupaPup with no plans, it’s the best little toy plane Ive flown, and I’ve flown many! there is already a 3300 jab powered aeropup that goes really well i heard.
MarkF50 Posted May 13, 2024 Posted May 13, 2024 2 hours ago, Flightrite said: Rollo with a 120 HP donk that should make the pup just about perfect👍80 Hap I consider under powered, a Rotax 200 gee gee would be the sweet spot👍 Shame about the SupaPup with no plans, it’s the best little toy plane Ive flown, and I’ve flown many! I know someone with a Jab 3300 in his. Eats up useful load what with the extra weight and extra fuel. Also his cruises at 90kt. Much better climb performance though.
BrendAn Posted May 13, 2024 Posted May 13, 2024 11 minutes ago, MarkF50 said: I know someone with a Jab 3300 in his. Eats up useful load what with the extra weight and extra fuel. Also his cruises at 90kt. Much better climb performance though. I thought the fuel tanks would be the same . Engine is 22 kg more.
Rollo Posted May 14, 2024 Posted May 14, 2024 Agreed completely. We have another aircraft called the Magpie that flies very well. Single seater, this aircraft been flying for Years. All the Computer work completed, and ready for production. This maybe a suitable replacement for the Supapup. Shall pop some pictures up soon on this site. Rollo 1 1 2
Rollo Posted May 14, 2024 Posted May 14, 2024 Yes was wondering about 90 knot cruise. The one I had for very short time cruised in mid 80's with Rotax 80hp. Jabiru 3300 I would have thought be up around the Ton (100knot) You mentioned great climb, maybe a climb prop rather than a cruise prop. Only a suggestion from me. 1
MarkF50 Posted May 14, 2024 Posted May 14, 2024 On 13/05/2024 at 7:53 PM, BrendAn said: I thought the fuel tanks would be the same . Engine is 22 kg more. He's installed extra fuel tanks and done some other mods too (like dual joysticks). I thought the pups came with different sized tanks? Mine has 2 x 26l wing tanks plus an 8l auxiliary tank in front of the RH rudder pedals. I'd heard that some pups have larger tanks - like 45l? I should say I've been *told* that my pup has 2 x 26l wing tanks. I have yet to verify this.
BrendAn Posted May 14, 2024 Posted May 14, 2024 17 minutes ago, MarkF50 said: He's installed extra fuel tanks and done some other mods too (like dual joysticks). I thought the pups came with different sized tanks? Mine has 2 x 26l wing tanks plus an 8l auxiliary tank in front of the RH rudder pedals. I'd heard that some pups have larger tanks - like 45l? I should say I've been *told* that my pup has 2 x 26l wing tanks. I have yet to verify this. I just assumed that they would have the same tanks . I see what you mean now, those 45 lt tanks would add a fair bit of weight.
Rollo Posted December 3, 2024 Posted December 3, 2024 On 13/05/2024 at 8:23 PM, BrendAn said: I thought the fuel tanks would be the same . Engine is 22 kg more. There is a new Aeropup build that has a Jabiru 3300. It's cruise speed is above 100 knots 1
facthunter Posted December 3, 2024 Posted December 3, 2024 With the same engine a J 230 does about 115 knots Nev
MarkF50 Posted December 4, 2024 Posted December 4, 2024 @Rollo there's someone at YGAW with a puppy with a 3300 in it. He cruises around 90kt. Maybe the newer designs go faster? @facthunter yes you might get the extra speed but you miss out on the boxy fuse and all those struts and braces that give the Aeropup its drag - and its charm. 🙂 1
facthunter Posted December 4, 2024 Posted December 4, 2024 Yes there's not a lot of point in overpowering a draggy plane. You'll get into the Air quicker but not much else.. Nev 1
Rollo Posted February 2 Posted February 2 On 04/12/2024 at 11:02 AM, MarkF50 said: @Rollo there's someone at YGAW with a puppy with a 3300 in it. He cruises around 90kt. Maybe the newer designs go faster? @facthunter yes you might get the extra speed but you miss out on the boxy fuse and all those struts and braces that give the Aeropup its drag - and its charm. 🙂 The Aeropup with Jabiru 3300 is cruising at 100 knots. One new aircraft has approximately 20 hours with this set-up. 1
Rollo Posted February 2 Posted February 2 48 minutes ago, Rollo said: The Aeropup with Jabiru 3300 is cruising at 100 knots. One new aircraft has approximately 20 hours with this set-up. Aeropup Australia has a New Website www.aeropup.com.au
BrendAn Posted February 2 Posted February 2 On 04/12/2024 at 9:10 AM, facthunter said: With the same engine a J 230 does about 115 knots Nev What's your point. We know jabs are slippery. That aeropup can land in a paddock. Can a j230 do that without folding up the nose wheel and cartwheeling
facthunter Posted February 2 Posted February 2 My point as I've already stated is there's not a great deal of advantage in over powering a draggy plane except it will get into the air faster but weigh more and use more fuel and be able to carry less weight... Nev 1
MarkF50 Posted February 8 Posted February 8 (edited) On 04/12/2024 at 12:37 PM, facthunter said: Yes there's not a lot of point in overpowering a draggy plane. You'll get into the Air quicker but not much else.. Nev Pups are light but. Mine is 40kg lighter than the club's 170s. A bigger engine could let you carry more but we but up against that 600kg limit. Edited February 8 by MarkF50 2
AKthePirate Posted 22 hours ago Posted 22 hours ago Hi all. Just came across this forum. keen on any recent updates on the Aeropup. Anyone flying with a Rotax 912? What is realistic build time for amateur? thanks.
Rollo Posted 15 hours ago Posted 15 hours ago Hi, yes there are Aeropups with Rotax 912. I had one here with 80hp rotax. Nothing wrong with it. There are many engine options these days. A new built Aeropup with Jabiru 3300 flying with about 25 hours on it. Cruise above 100knots. With the new Instructions available on our Website and access to other builders, I would think 400-500 hours would be reasonable to build. As the manufacture, we now offer more finished items in the kit. For example, we machine out the main webbed spar for you. We can offer "Fast build Wings" for a quicker build time. Our Website address below https://www.aeropup.com.au/ Any questions feel free to ring. Rollo
Flightrite Posted 4 hours ago Posted 4 hours ago 10 hours ago, Rollo said: Hi, yes there are Aeropups with Rotax 912. I had one here with 80hp rotax. Nothing wrong with it. There are many engine options these days. A new built Aeropup with Jabiru 3300 flying with about 25 hours on it. Cruise above 100knots. With the new Instructions available on our Website and access to other builders, I would think 400-500 hours would be reasonable to build. As the manufacture, we now offer more finished items in the kit. For example, we machine out the main webbed spar for you. We can offer "Fast build Wings" for a quicker build time. Our Website address below https://www.aeropup.com.au/ Any questions feel free to ring. Rollo Rollo I follow the guy (Don Fieldon)in the States Aeropup USA and he’s been building his demo one for years now!
