stevron Posted July 29, 2023 Posted July 29, 2023 What LSA will fit a 190 cm pilot, mostly leg room required?
Old Koreelah Posted July 29, 2023 Posted July 29, 2023 I’m taller than that and fit in even the smallest Jabirus. Skyfox is too damned small.
Kiwi Posted July 29, 2023 Posted July 29, 2023 17 minutes ago, Old Koreelah said: I’m taller than that and fit in even the smallest Jabirus. Skyfox is too damned small. Yes, but you have build of a star picket. 3
Bennyboy320 Posted July 29, 2023 Posted July 29, 2023 I’m 192cm & 96kg, I fly the Foxbat A22LS, VERY spacious with lots of leg room. Highly recommend this a/c. 1
MattP Posted July 30, 2023 Posted July 30, 2023 I'm also about 192, and about 93kg. Legs are quite long, so does pose some challenges in GA and LSA alike, but: Tecnam P92 and derivatives - ok, once you're in Jab (small and "big") - I find the dashboard cuts into my shins / knees in a way that I can live with for short spurts, but I generally don't feel comfortable for what that could mean in some kind of forced landing. I also find the seating position just doesn't work for me. ALPI Pioneer's - Ok, headroom / legroom ok. Tecnam Low wing (Sirerra) - headroom ok Texan - Headroom ok, legs ok. Â GA Pa28 - ok with the seat fully back against the stops and down its lowest setting, some challenges with using a kneeboard and the yoke. C172 - slightly better than the Pa28 C182 - no issues. Cirri - no issues. 1
Steve L Posted July 30, 2023 Posted July 30, 2023 I would look at the Eaglet with its adjustable seats, one has to be a contortionist to get your head in though. Even better If a central single control yoke was available.  steve 1
skippydiesel Posted August 3, 2023 Posted August 3, 2023 ATEC Faeta - adjustable seating/leg room and one of the widest speed envelopes (27-134 knots) of all 912ULS powered aircraft 1
