Recently had a seal in my left side calliper cylinder fail and dump the mineral oil. Can any member advise of any issues that may make repair of Savannah disc brakes difficult? As all the pads are pretty low, will be replacing all the pads and seals for both callipers and master cylinders. Thanks in anticipation.
Thanks Mark. Is replacing the seals a difficult job and do you know if there is a detailed exploded view of the brake system available
