BillLipson Posted September 16, 2022 Posted September 16, 2022 Recently had a seal in my left side calliper cylinder fail and dump the mineral oil. Can any member advise of any issues that may make repair of Savannah disc brakes difficult? As all the pads are pretty low, will be replacing all the pads and seals for both callipers and master cylinders. Thanks in anticipation.
Kyle Communications Posted September 16, 2022 Posted September 16, 2022 Sometimes you need to put a washer infront of the piston. when the pads get low the piston will pop out
BillLipson Posted September 28, 2022 Author Posted September 28, 2022 Thanks Mark. Is replacing the seals a difficult job and do you know if there is a detailed exploded view of the brake system available
Kyle Communications Posted September 29, 2022 Posted September 29, 2022 The pistons will come out easily..but the piston itself is not big enough thats why when your pads get low the bloody piston can come out
BillLipson Posted September 29, 2022 Author Posted September 29, 2022 Thanks Mark Appreciate the advise
