APenNameAndThatA Posted April 29, 2020 Posted April 29, 2020 I managed to pass my nav flight, so I thought I would share some of my tricks - some of which came from here. I used removable sticky tape to write colour-coded cues for radio frequencies, altitudes, radio calls and transponder/ATIS/QNR and pre-landing checks. I drew five mile circles around all the aerodromes, and five and 10 mile circles around the aerodrome that I intended to land at. That prompted me to notify aerodromes when I was passing close to their pattern, and do landing checks (five miles) and do approach calls where I was landing (10 miles). By doing the call at exactly 10 miles, ETA = T + 7, in my plane. I also coloured the border of the different maps with different highlighters. That enabled me to get the correct side of the correct map easily. For my destination airport, I wrote the elevation, circuit height and overflying height, CTAF, runway names, and if the circuit was left or right (S or Z - shaped) so I could picture the runway names and dead side as I approached the aerodrome to overfly it. With the heights all written down, I would not have to do maths under pressure. I must say, none of this info is presented this way on electronic displays, so at the moment, I plan on using paper maps for navigation and GPS just to confirm my position. All comments welcome, and the more critical the better - negative feedback is valuable. 3
APenNameAndThatA Posted April 29, 2020 Author Posted April 29, 2020 P.S. You can also use the removable sticky tape to sticky tape shut the bits of the map that I was not going to need. Apart from that, I was just using the standard sheet with the headings and times, and a couple of checklists, especially the clear off checklist.
old man emu Posted April 29, 2020 Posted April 29, 2020 I used to cover my WAC charts with clear vinyl and write on them with a china pencil. 2 1
APenNameAndThatA Posted April 29, 2020 Author Posted April 29, 2020 I used to cover my WAC charts with clear vinyl and write on them with a china pencil. That would stop them wearing out.
old man emu Posted April 29, 2020 Posted April 29, 2020 The trouble nowadays is that you have to replace your various maps every time CASA adds a full stop. 1 2
Thruster88 Posted April 29, 2020 Posted April 29, 2020 The trouble nowadays is that you have to replace your various maps every time CASA adds a full stop. One of the benefits of an EFB, keeping all the paper current was the thing I hated most about flying before oz. 2
Yenn Posted May 7, 2020 Posted May 7, 2020 I can remember the good old days of getting updates for the WAC charts, had to put them on the chart by hand. That as before VNC charts. 1
Bruce Tuncks Posted August 3, 2020 Posted August 3, 2020 Clear tape you can write on and which does not damage the map when it comes off? Where do you get that? I like to use ozrunways as well as a map. most of the time, you just have to keep the blue plane near the pink line on the display... and I reckon a smart guy could set it up so that you got a reminder when a radio call was required. Since I'm not smart, I like the idea of marking the map.
Downunder Posted August 3, 2020 Posted August 3, 2020 and I reckon a smart guy could set it up so that you got a reminder when a radio call was required Add a waypoint on your pink line where the call is required. Name the waypoint your frequency. It won't become permanent on the map, just on that plan. I use it for area frequency boundaries and QNH boundaries.....you could put it 10 nm out (or whatever) from airports as well with the ctaf freq..... 4 1
turboplanner Posted August 4, 2020 Posted August 4, 2020 Stick a sheet of clear on to your map, then use Chinagraph pencils. The map doesn't blow around as much, water resistant and you can erase eacg trip or keep regular routes etc. 1
Bruce Tuncks Posted August 4, 2020 Posted August 4, 2020 Thanks downunder... thats easier than I thought!
Kenlsa Posted August 4, 2020 Posted August 4, 2020 Paper maps always work, no matter what any electrons are doing. In a previous capacity as an aircraft plotter for our Rapier battery, we used clear plastic (talc) with chinagraph pencils to plot a/c positions. Wipe the marks off after an engagement and start again and not sacrificing a map and to keep the treasurer happy. Ken 1
spacesailor Posted August 4, 2020 Posted August 4, 2020 Not so good in a rainy day, when wet. spacesailor
coljones Posted August 4, 2020 Posted August 4, 2020 Clear tape you can write on and which does not damage the map when it comes off? Where do you get that? I like to use ozrunways as well as a map. most of the time, you just have to keep the blue plane near the pink line on the display... and I reckon a smart guy could set it up so that you got a reminder when a radio call was required. Since I'm not smart, I like the idea of marking the map. Search for removable magic tape. I failed the parental book covering course. I bought some China graph pencils but they melted in a Sydney heatwave. I use OzRunways with paper as a backup, I use the old maps to wrap presents. 2
Jase T Posted August 4, 2020 Posted August 4, 2020 Nice work. You can’t beat the 8 P’s when it comes to nav prep! I also talc and use chino on my WAC’s (and on the big clear whiteboard beside me as well sometimes) and 2b pencil on the ones that you replace a lot. Love OzRunways but always take and plot ona paper map (even just postn Fox’s and times will do)...
APenNameAndThatA Posted August 4, 2020 Author Posted August 4, 2020 Clear tape you can write on and which does not damage the map when it comes off? Where do you get that? I like to use ozrunways as well as a map. most of the time, you just have to keep the blue plane near the pink line on the display... and I reckon a smart guy could set it up so that you got a reminder when a radio call was required. Since I'm not smart, I like the idea of marking the map. Scotch Magic Removable Adhesive Tape. Officeworks online. I don't think it is availble from the shops.
coljones Posted August 5, 2020 Posted August 5, 2020 Paper maps always work, no matter what any electrons are doing. In a previous capacity as an aircraft plotter for our Rapier battery, we used clear plastic (talc) with chinagraph pencils to plot a/c positions. Wipe the marks off after an engagement and start again and not sacrificing a map and to keep the treasurer happy. Ken Where do you get talc from? Or are you using Clear Contact?
Kenlsa Posted August 6, 2020 Posted August 6, 2020 Col, haven't bought any in many years, used to get it at our news agent, in one square metre sheets that we cut to size. I think Talc was a trade name but it was hard clear plastic af about 1mm thickness, much like the old shirt box cover. Office Works may have a similar product. Ken 1 1
Jase T Posted August 6, 2020 Posted August 6, 2020 Where do you get talc from? Or are you using Clear Contact? These days I get them laminated. Go to Office works they will do the entire map, then decide carefully where you want to fold it!!!! Sorry Talc is like saying an esky... It used to be a thing now its just a generic name. 1 1
Paulmilo Posted August 15, 2020 Posted August 15, 2020 Clear tape you can write on and which does not damage the map when it comes off? Where do you get that? I like to use ozrunways as well as a map. most of the time, you just have to keep the blue plane near the pink line on the display... and I reckon a smart guy could set it up so that you got a reminder when a radio call was required. Since I'm not smart, I like the idea of marking the map. AvPlan and I assume OzRunways allows you to ‘draw’ on your map (annotate) so you can combine “old skool“ with your EFB. I draw on things like radio calls and L / R hand ccts. Under settings, select annotate and then you can draw, erase etc.
coljones Posted August 21, 2020 Posted August 21, 2020 Chart Lamination Service (Per Chart) - FlightStore
Bosi72 Posted September 10, 2020 Posted September 10, 2020 Do whatever makes your workload easier. Regarding your actual markings, do you really want to be at A018 a couple of miles before Mt Joyce (1539)?
old man emu Posted September 10, 2020 Posted September 10, 2020 $5.50 from OfficeWorks plus a bit of careful work. https://www.officeworks.com.au/shop/officeworks/p/studymate-self-adhesive-book-cover-roll-450mm-x-5m-clear-sm5450
_db_ Posted September 29, 2020 Posted September 29, 2020 Also if you use AVPlan you can have the circles drawn (at set intervals) around your aircraft so you know how far away you are from an airport. So this can eliminate the need to draw on a physical map.
old man emu Posted September 29, 2020 Posted September 29, 2020 RAAus - get back to basic flying! But I want the electronic whizz-bangery of a long haul heavy. 1
