Garfly Posted February 6, 2019 Posted February 6, 2019 It's a lot different when it's real; you can sense it dawning on the pilot that :"This is not an exercise". It's the real-time/real-life nature of this clip that makes it easy to empathise - and thus take your own lesson from it. And then, of course, there's the usual monday-morning-quarter-backing in the comments section. 1
ClintonB Posted February 6, 2019 Posted February 6, 2019 That’s not a lot of time from stoppage until the ground is there. Maybe time for some practice next flight.
kgwilson Posted February 6, 2019 Posted February 6, 2019 It's a trike so not surprising. Better L/D than a brick but not much.
BLA82 Posted February 6, 2019 Posted February 6, 2019 It's a trike so not surprising. Better L/D than a brick but not much. That’s a funny looking trike??? 1
kgwilson Posted February 6, 2019 Posted February 6, 2019 Sure is. never seen a 3 axis one before. Glides like one though. 1
Litespeed Posted February 6, 2019 Posted February 6, 2019 In the end he did well, and looks survivable. Looked like there were better spots though like a road alongside one of the fields. But that is easy say after the fact. Looks more like a modern version of a thruster.
kasper Posted February 7, 2019 Posted February 7, 2019 Looks more like a modern version of a thruster. Looks like a NZ built b22 Bantam ... but I’ve not seen one of those without the rear fuselage covering on ... but j2200 engine and bubble windscreen really looks like a b22 and not a t600 thruster.
FlyBoy1960 Posted February 7, 2019 Posted February 7, 2019 The aircraft is built in South Africa under the name Bat Hawk, it is manufactured under some sort of licensing agreement with the original manufacturer in New Zealand (Max Clear, if my memory serves me correctly) before his passing. This particular model is the Bat Hawk B22J with the letter J standing for Jabiru engine. I wonder why the Jabiru engine stopped, you can see fuel in the fuel line and after the accident so it was not fuel starvation. Not an expert but I agree with previous comments that it glides like a brick and they looked to be many other more suitable areas to land. 1
biggles Posted February 7, 2019 Posted February 7, 2019 Not an expert but I agree with previous comments that it glides like a brick and they looked to be many other more suitable areas to land. Probably looked pretty good at the final turn, and you are generally committed by then. Late low level manoeuvres, particularly by low hour pilots not recommended. Have a plan and stick with it. Keep the plane flying for as long as possible, keeping the nose wheel off the ground for as long as possible. I have concerns about the fuel line to the pump flapping around, seemingly unrestrained. Should be proper fuel hose enclosed in a fire proof sleeve ...... Bob
Hargraves Posted February 16, 2019 Posted February 16, 2019 One of the better engine out vids (sick) that shows exactly why we are taught hight, equals time, equals safety, with no substiutes, hope they were ok, he was able to ask at the end so maybe so, cheers hargraves
BackcountryAeropup Posted February 16, 2019 Posted February 16, 2019 That paddock got real ugly at the end there. Evan with bush wheels it would have been a workout.
Thruster88 Posted February 16, 2019 Posted February 16, 2019 One advantage of being a farmer is you can spot a deep ripped paddock from 2000'. The pilot did a good job of keeping his airspeed up, could have slowed it more at the end, was he into wind?. My Thruster would handle that field with it's 6.00x6 tyres and the 582 wouldn't have failed in the first place (just kidding). Nobody died always a good result.
JG3 Posted February 16, 2019 Posted February 16, 2019 Select a vehicle track if possible. There must have been several around those fields.... 2
