just fitted a new battery in my plane , 914, and noticed after fitting the positive that when I touched the negative it produced a small spark , everything turned off, where would I be loosing current.
From the one thing that is not off. Do you have a multimeter handy & know how to use it?
Maybe Clock ( if fitted) or charge current for electrolytic noise suppression capacitor ( if fitted) ??
It does have a cap fitted and I did wonder if it was the culprit, doesn’t seemed to have lost any voltage after two days so maybe okay
Happens with cars mate, First connection with a new battery the customer thinks that they have a drain and that you should find it for them for free (they only came in for a new battery), With an inline ammeter you can see the spike in the initial connection - then watch it plateau out.
