Geoff13 Posted August 20, 2016 Posted August 20, 2016 I am trying to source some 10mm Bungee Cord and am not having much luck. Any ideas on where I could get suitable aircraft grade in or around Brisbane please?
Geoff13 Posted August 20, 2016 Author Posted August 20, 2016 Thank you skeptic36. I actually bought some standard grade stuff and it simply does not have the same strength as what is already on the aircraft. I am not even sure if I can get aircraft grade as I can't seem to find any reference to it anywhere, but the stuff I purchased online will simply not do. Mine is still quite serviceable but it is out of date so I need to look for a replacement.
skeptic36 Posted August 20, 2016 Posted August 20, 2016 I'm not sure about aircraft grade, and I haven't bought any for years, but the Nolan stuff used to be above average quality
Blueadventures Posted August 20, 2016 Posted August 20, 2016 Thank you skeptic36. I actually bought some standard grade stuff and it simply does not have the same strength as what is already on the aircraft. I am not even sure if I can get aircraft grade as I can't seem to find any reference to it anywhere, but the stuff I purchased online will simply not do. Mine is still quite serviceable but it is out of date so I need to look for a replacement. ASAP at Learjet drive on the road to your air field. And it'll be top quality aircraft grade. 1
Geoff13 Posted August 21, 2016 Author Posted August 21, 2016 ASAP at Learjet drive on the road to your air field. And it'll be top quality aircraft grade. Thank you I was actually going to go and see them later this week. :)
Blueadventures Posted August 21, 2016 Posted August 21, 2016 I meant to also say if you need suitable 10mm ferrules the attached is the ones I ued on my skyfox undercarriage bungees. If the skyfox data doc is attahed ignore it as I don't seem to be able to delete it. Cheers Mike Skyfox data.doc 10mm ferrule.doc Skyfox data.doc 10mm ferrule.doc Skyfox data.doc10mm ferrule.doc
