JerzyGeorge Posted April 18, 2016 Posted April 18, 2016 Hi All, I have discovered pretty cool place to install tablet. It is easy to read even in bright sun ( because it is sheltered from it), does not obstruct outside view, and fuel gauge is still easy to read. Perhaps will need external GPS antenna if signal is average. I use Easy VFR software and love it , would recommend it any time. Please have a look at the photos Obviously install at your own risk , the same like flying Savannah. George
JerzyGeorge Posted April 18, 2016 Author Posted April 18, 2016 Sorry Guys , could not get orientation of the photos right . Do not know how to fix it. George
Xavier Posted April 18, 2016 Posted April 18, 2016 Hi George, I use the same spot on my little VGs. I found that not having it on the front panel stop me from looking at it too often, which is a good thing. I am using a Bluetooth Bad Elf external GPS connected to the iPad, better signal and it also significantly increases the battery life. I like your idea of the pen holder. Xavier
Kyle Communications Posted April 18, 2016 Posted April 18, 2016 I used to have my Ipad in the same spot but found it to be hard to use in bumpy conditions also being a big guy it was difficult to use. I swapped it to the right hand side and it was also very difficult because of the centre stick. I have since converted my Sav to twin sticks and have mounted a Ipad mini in the dash using a Airgizmo mount. I am very happy with this installation but having the twin sticks makes it very easy 1
Ayecapt Posted April 24, 2016 Posted April 24, 2016 Like the pencil holder as well. Is it a couple of those spring open plastic clips or somthing else?
