Neil_S Posted November 13 Posted November 13 1 hour ago, skippydiesel said: I just couldn't watch the above video/rant all the way through. I am sure there are some gems of wisdom in there somewhere. The bits I did watch, came across as the pilot can (with appropriate practise) always deliver the perfect landing - BS! To deliver the perfect landing not only requires skill but LUCK! Why luck , simply because humans can not see air movements. We will always be reacting / behind the effects of air movement (wind speed, direction & consistency) on our aircraft. Practise will never make you the perfect pilot but will go along way to giving you the skills to respond appropriator to the dynamic environment we fly in. Landings are great "levelers" - the very best pilot can still make a crappy landing, be shown up by a low hours student. 😈 I did my BFR last week, and frequently when I have a passenger my landings are somewhat smoother as the extra weight gives the plane extra inertia, but my landings during the BFR with an examiner/instructor next to me were very ordinary (ie crappy!). On the way back I stopped in at Melton for one of their excellent cappuccinos and my landing was an absolute greaser! I think it's called Sod's Law! Cheers, Neil 2
facthunter Posted November 13 Posted November 13 I always got check-itis and didn't sleep the Night before. Nev
Moneybox Posted November 16 Posted November 16 I'm sure there's a big difference in aircraft. I'm not a very experienced pilot but I've been fortunate to have trained in a few different ones. I started out in the Evektor Harmony, had a few days in the Bristell then the Jabiru J160 and J170. After that I got the Sportstar registered and after it was damaged bought the Zenith 601HD. I had some good landings but a lot of crappy ones in all of the above apart from the Zenith. This little plane has no flaps, there's no reason to fiddle with the trim and I just loves to land. I have to say in the 40 or so hours I've never had a crappy landing. It has to be the plane. For one thing there's nothing to fiddle with distracting me from lining up the strip and controlling the speed and decent. It as simple as point it in the right direction and control the throttle. I'd like a fancy plane but there I think there are advantages in simplicity, especially for a oldy like me. 3 1
facthunter Posted November 17 Posted November 17 Low wing gives better ground effect. Never touch down nosewheel first. Never let the upwind wing rise. Nev 3
