Camel Posted August 18, 2015 Posted August 18, 2015 Can anyone recommend Type or brand of manometer for testing Altimeter and Airspeed indicator. Thanks
Camel Posted August 18, 2015 Author Posted August 18, 2015 Can anyone recommend Type or brand of manometer for testing Altimeter and Airspeed indicator. Thanks
crashley Posted August 18, 2015 Posted August 18, 2015 a piece of clear plastic hose filled with water and a tape measure
spacesailor Posted August 18, 2015 Posted August 18, 2015 Try this link: http://www.eaa1000.av.org/technicl/instcal/instcal.htm : spacesailor
Blueadventures Posted August 19, 2015 Posted August 19, 2015 This may assist. Put food dye in the water to improve the contrast, you also need another bleed valve so as you attach the syringe the needle does not move and when inserted close this bleed valve and your readings are from 0. Cheers Mike 1
Blueadventures Posted August 19, 2015 Posted August 19, 2015 This may assist. Put food dye in the water to improve the contrast, you also need another bleed valve so as you attach the syringe the needle does not move and when inserted close this bleed valve and your readings are from 0. Cheers Mike Manometer.pdf Manometer how to build EAA Sport Aviation in August 2006.doc Manometer.pdf Manometer how to build EAA Sport Aviation in August 2006.doc Manometer.pdfManometer how to build EAA Sport Aviation in August 2006.doc
Old Koreelah Posted August 19, 2015 Posted August 19, 2015 Try this link: http://www.eaa1000.av.org/technicl/instcal/instcal.htm :spacesailor Thanks for that Spacey. Quite topical really, I've used this method to test the ASI, and was recently advised to recalibrate my Alt.
