old man emu Posted November 28, 2011 Posted November 28, 2011 Then there was the fanatical Greenie who designed and constructed his own electrically powered airplane. He was really keen about Ohm-builts. OME 3
Bryon Posted November 28, 2011 Posted November 28, 2011 Betcha he met some resistance from his current missus 2
facthunter Posted November 28, 2011 Posted November 28, 2011 I believe the outcome was quite shocking. It had the potential to be. Nev 4
Guest DonningtonSmythe Posted November 28, 2011 Posted November 28, 2011 Certainly generated some laughs! :-)
Tomo Posted November 29, 2011 Posted November 29, 2011 This has the capacity to go much further. Watts next?
facthunter Posted November 29, 2011 Posted November 29, 2011 It depends on how you conduct the operation. If you insist on overcharging, you will get some resistance to that. Nev
Tomo Posted November 29, 2011 Posted November 29, 2011 you will get some resistance to that. Nev A bright idea indeed.
planedriver Posted November 29, 2011 Posted November 29, 2011 Bet he gets wired later on.... Obviously it's a single seater, without a conductor.
Guernsey Posted November 30, 2011 Posted November 30, 2011 Bet he gets wired later on.... Unless he's been insulated from the problem.
farri Posted November 30, 2011 Posted November 30, 2011 But he`s positive it will fly and everyone is just being negative! Frank.
justplanecrazy Posted November 30, 2011 Posted November 30, 2011 I bet CASA would charge him to some capacity!
old man emu Posted November 30, 2011 Author Posted November 30, 2011 I think I well and truely discharged my duty as a humorist. OME
Guernsey Posted November 30, 2011 Posted November 30, 2011 It just goes to show that we all have a 'potential difference'.
Guernsey Posted November 30, 2011 Posted November 30, 2011 Wow, The puns in this thread are revolting. Stand by....I think we have Ignition. 1
pudestcon Posted November 30, 2011 Posted November 30, 2011 Wow, The puns in this thread are revolting. That could be inflammatory iggy Pud
bushcaddy105 Posted November 30, 2011 Posted November 30, 2011 And it was obviously test flown at Watt's bridge
Tomo Posted November 30, 2011 Posted November 30, 2011 And it was obviously test flown at Watt's bridge I wonder how much the test pilot charged him? 1
Trevor Posted November 30, 2011 Posted November 30, 2011 I bet it is solar powered. I wonder watt the kilowatt output will be? Need a panal to work it out - I would bank on it!
