Spin Posted September 26, 2010 Posted September 26, 2010 Extract from the latest RVator, the Vans aircraft online magazine. Dick Van Gruesen is known as one of the thinkers and straight shooters of the homebuilt aircraft design fraternity and I found it interesting and a little disappointing to read that in the case of electric power for aircraft, as with so many other emerging technologies, promises seem to have run well out ahead of delivery. Maybe I'll have to wait a little longer before adding an "elec" endosement........ "A year ago, following AirVenture 2009, I wrote an article on electric powered airplanes from my perspective as an owner/operator of one. I compared and contrasted my actual electric aircraft operating experience with the reports and projects being published. Since then, the “press release” news has continued, and I have continued operating my electric self-launch Antares 20e sailplane. Since June of 2009, I have logged over 400 hours of flight time. Just 15 hours of this was “under power”, usually five or ten minutes at a time. This practical application experience has put me in a different position than most people writing or talking about electric airplanes. In our field of interest and endeavor, the calendar year runs from “Oshkosh to Oshkosh”. This year, again, there were a lot of talks and programs about electric airplanes, but not much action. Yuneec had another very interesting POC airplane on display. With a low wing and fixed tractor powerplant, it would normally be classed as a motorglider. It featured a single retractable landing gear and a folding prop to minimizing drag for soaring rather than motor flight. It really looks more like a self-launch sailplane than a general purpose sportplane or motorglider. I don’t mean this to be a bad thing, but rather a concession to the realization that electric technology is not ready for prime time GA; certainly not ready to power an airplane like the Cessna 150 or Katana. Neither of the Yuneec airplanes flew at Oshkosh this year. I heard that they had a system failure of some sort which prevented them from being able to fly. One of the leaders in electric airplanes has been Randal Fishman with his ‘Electraflyer’ aircraft. Starting with a weightshift trike several years ago, he advanced to the Electraflyer C — an electric motor powered Moni airplane in which he flew demonstrations at Oshkosh and Lakeland for a couple of years. He had a very nice looking Electraflyer-X prototype on display at Airventure 2009 but hadn’t flown it by Sun’N’Fun 2010, where it was on static display . I did not see or hear of it at Oshkosh this year, so don’t know what its current (pun intended) status is. The last entry on his website is dated July 2009. My friend Dave Nadler had his Antares electric sailplane on display at Oshkosh again this year and performed flight demonstrations during the airshow on two days. I’m not aware of any other electric airplane flying there this year, so the Antares sailplane still appears to be the industry leader. There are about fifty of them operating worldwide in the hands of private owners. Some have been in operation for five years or more. This would indicate that their system obviously works well, demonstrating that they have achieved a good level of operational reliability. Interestingly, the Antares does not get much attention from the aviation press, probably because it is a single seat, special purpose, quite expensive airplane. Why can’t the Antares electric motor system, or a similar level of technology be incorporated into a more general purpose airplane like the Yuneec or Electraflyer? It probably can, but I assume that these folks are working through the teething problems that the Antares people struggled with 10 years ago. It’s also possible that the folks at Yuneec, et al, are trying to develop a more affordable package, and thus not able or willing to “buy” the expensive components that have contributed to the success level that the Antares has demonstrated. Since the aviation press is not yet able to treat us to pilot reports of operating electric aircraft, here’s a few words about my experience. According to the factory information, the Antares has enough battery power to climb to approximately 9000 ft. at my normal operating weight. I have never verified this, and do not feel that it could be done in a single “open the tap and go” motor run. My experiencehas been that the indicated battery power starts to drop more rapidly after about 3000 ft. of climb. Normally, the motor is stopped and retracted at about this time; the start of a soaring (or gliding?) flight. After a few minutes following motor shut-down, the battery power indication will rebound by 10-15%. I have also found that by reducing the power to just enough to sustain level flight (about 25% output), the battery power will rebound somewhat and then drop slowly, commensurate with the low draw. It would seem that the batteries need to be “rested” periodically to re-balance themselves, either by shutting them off or operating them at a much lower continuous power draw like the “low cruise” mode. On an ideal flight, I would launch, using battery power to take off, and contact a thermal within a mile or so of the departure end of the runway. I would center the thermal, reduce power to 50% or less and establish that a positive climb rate is probable with no power. At that point, somewhere between 1500 and 2000 ft. altitude, I would stop the motor and retract motor pylon. The high-performance airplane would continue to climb and soar for hours without need to use motor to remain aloft. Total battery use would be 10-15%. A sample flight for a “poor” soaring day might be: Take-off and climb at about 80% power to 3,000 ft., at which time the power meter will be indicating about 60% or less. After turning the motor off and retracting it, the power level will rebound to about 70%. At a later point in the flight, I might find myself running out of thermals, altitude, and ideas. I extend the motor and climb about 1500 ft. in the process of getting to another thermal (or getting enough altitude to glide back home). In the process, the power meter may drop to around 35-40% and then rebound to about 50% as the batteries re-balance themselves. Tallying up, I would have climbed a combined total of 4500”: half of the specified performance capability, and used about half of the battery energy. My real world experience has basically validated factory claims. In the real world, I am rarely climbing in stable air. While climbing in sinking air, often unavoidable while trying to reach the area of the “house thermal” energy goes away quickly as the altimeter slowly winds upward. The reverse is true when the thermal gods smile on me, so the above examples are based on averages. During a long soaring flight, the flight instrumentation and radio will use about 2-4% of the battery energy, not enough to seriously deplete the energy available for a “save” if needed. Another characteristic of my system is that the motor should not be operated at high power (high battery discharge) when any of the battery temperatures are below 20 deg. C. When soaring at higher altitudes (low outside temps.), the battery temps can easily drop below 20 deg. C. To assure that the motor can be used if needed, there is a built-in battery heating system. The batteries draw from their own energy to heat themselves. This obviously reduces the available energy by a small amount. Normally, I do not activate the battery heater unless the flight is not going well and I feel that I may need to use the motor in the next 5 minutes or so. I do not waste energy keeping the batteries warm during an entire flight. If I should be distracted with the challenge of soaring flight and overlooked heating the batteries, I can still run the motor at low power (level flight or slight climb) while the batteries are heating. The problem is that cold batteries do not deliver energy well and may be damaged by attempting to draw high output when cold. This is true for other common type batteries as well. This is why your car may not crank well, or at all, in really cold conditions. Most of the general purpose electric sportplanes being developed or proposed quote flight duration available from their batteries. Its safe to assume that these flight times are based on low power settings and “economy cruise/ loiter” speeds. However, unless one is to cruise at an altitude of 10 ft., a fair amount of energy is needed to reach even a modest cruise altitude. In the case of my Antares, normal climb rate of 5-6 hundred fpm requires a power draw about 4 times that of level flight. So, a large percentage of the available energy is used just getting to altitude. I suppose that at the end of the flight, gliding back down to landing with the motor throttled or shut off, some of this can be offset. Still, it’s a factor to consider, as would be traffic pattern delays at the end of a flight. The bottom line is that, from my experience, electric aircraft operation is not necessarily as “plug-and-play” as some advocates would like you to believe. In some respects, it is. For instance, operating the motor is as simple as pushing a lever forward----the equivalent of ignition, primer, starter, throttle, mixture control, etc., all in one operation. On the other hand, there are concerns such as the limited energy (range) available, and the battery temperature issue. We can continue to hope for breakthroughs to alleviate these concerns, but in reality we probably must not expect more than incremental gains in the near future."
Gnarly Gnu Posted September 26, 2010 Posted September 26, 2010 Electric motor powered aircraft are 100% viable, it's the extension lead that is the killa......
facthunter Posted September 27, 2010 Posted September 27, 2010 extension lead. Especially with aerobatics. Adds a new meaning to getting involved with powerlines. New form of flying. I could become absolutely wrapped in it... Nev
Methusala Posted September 27, 2010 Posted September 27, 2010 Battery power assisted flight. G,day All, Interesting read! Mate and I are building a Mike Sandelan GOAT4 ulrtralight primary glider. Launch means are under consideration and we are quite interested in the developing model a/c technologies which utilise Li/Po energised "outrunner" motors. The most powerful example to date is eqivalent to a 20 h/p 2 stroke! This weighs around 2.5kg and with enough battery capacity to run for around 15 minutes will only weigh twice this.Of course the mission will be similar to that described in the foregoing article, not a cruising sport plane. This type of power unit would have been unthinkable not many years ago. Let the march of development proceed apace. Regards, Don
Guest disperse Posted September 27, 2010 Posted September 27, 2010 I'm of the belief that electric powered vehicles including planes. Is just waiting for either the right storage system (battery) or the right production ie: Hydrogen cells and the like.
Methusala Posted September 27, 2010 Posted September 27, 2010 Saw a piece on ABC - may have been Catalyst, that talked about using nano-tech to create capacitors that used much less mass to store electricity and could be charged quickly at high rates. This is the type of advance that will unlock potential in electric flight.
Gnarly Gnu Posted September 28, 2010 Posted September 28, 2010 'Super caps' (very high value capacitors) are a fantastic advance but one problem is that unlike a battery a capacitors voltage decreases at a linear rate during discharge. They are a great addition to supplement battery power to assist with periods of high current draw for example but using capacitors for power alone? I suggest not anytime real soon. Been wrong before of course....:)
