It's called the Aeriane 'Swift' worth about 25,000euro for just the wing. you can unbolt the footlaunch hang cage and wheel in a power pod available in several different hp engine combinations with a folding prop. i saw a couple when i was in Italy. the wing is amazingly light.
ozzie
It's called the Aeriane 'Swift' worth about 25,000euro for just the wing. you can unbolt the footlaunch hang cage and wheel in a power pod available in several different hp engine combinations with a folding prop. i saw a couple when i was in Italy. the wing is amazingly light. ozzie
Thank you Ozzie
