Can anyone advise how much it would cost to fully recover a Gazelle and where in NSW I could get it done?
  • 8 months later...
Guest aussie carl
Does anone have a rough estimate of what the material alone for the above mentioned aircraft would cost and where to get it from please.
Guest aussie carl
Thanks Mat.
Carl
Hi Aussie Carl. To add to matt's info. If you need alloy hangers to fit to the wings a source is Gymipe aircraft maintenance at $300 each therefore the full 10 are $$$$'s. Mine has the ply ones in good nick so if I do them I might do the strut and inner ones first (four in total.) as a progessive maintenance plan. However if recovering the wings I'd give serious consideration to doing all ten.
Cheers and safe flying
Mike
Guest aussie carl
Thanks Mike.
I was just doing some estimates before a possible purchase of an aircraft, but looks like it has been purchased before I had a chance to look at it properly.
No matter, I say if someone else wanted it reel bad then "it's theres" .
I will buy one some time but only when I know for sure.
Guest aussie carl
nose wheel colapsed on landing I believe. Front end RS. Wing tubes bent, prop strike, usual stuff. No matter I was a bit sus on it but after doing some estimates it is likley to cost 25K + my time to get it in the air so I am not realy conserned about missing out.
